LOUD KNOCK! newly installed motor w/ freshened up head
Old Nov 14, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
i had a question for all you guys... i installed a new motor from a member on this forum (said to be rebuilt with new bearings and piston rings) and everything seems fine in the block.. i previously had my old head refreshened meaning all new seals etc etc. so pretty much a brand new head. the head ran fine on another motor after all the work was done to it. i simply took the head off of my old motor and put it on my new one. i did not touch one thing on it. the timing belt is on correctly as well, no skipped tooths..
however there is a loud knock that seems to come from the intake side of the head. the con rod and bearings/bolts are fine on all of the cylinders, a valve didnt drop either.. the knocking noise seems to come from the top of the motor (valves/pistons) . the knocking noise is very quiet at idle but when i give it the slightest gas (over 1000rpm), the knocking noises volume increases dramatically. i checked the valve clearances on all the valves and they are all within spec.
i grounded out each spark plug to see if the knocking noise would be lessened/eliminated (by removing the coil pack in each cylinder) and no luck, the knocking still remains the same. so my obvious guess would be its coming from the head. normally i would think it would be the valves but the valve clearances are fine. sssssssoooooooooooo.
whats the deal!? HHHHHAAALPP!
Old Nov 14, 2008
WannaBFast's Avatar
Prowlin' with a Purpose
Re: LOUD KNOCK! newly installed motor w/ freshened up head
more info! is it a vtec head?
was there assembly lube in everything before you started it up?
Old Nov 15, 2008
vtec head, the guy that i bought it from works at a shop and he assembled it and shipped it to me so i hope he used assembly lube! i primed the motor until the oil pressure light was off on the first start up as well.
Old Nov 15, 2008
i need help desperately bump.
Old Nov 16, 2008
ttt. I need help. I know there are tons of engine gurus on here...
Old Nov 16, 2008
speedfoos's Avatar
Sounds like you need to drop the pan and the girdle and have a look at the main bearings. Did you check to make sure all the rocker caps were torqued down when you checked the valve lash?
Old Nov 17, 2008
^^i am going to drop the oil pan and check that out, if all seems good there i will rip off the head too.. i didn't check the rocker caps when i did the valve clearances. originally i would expect everything to be good yno? i will check the caps and jazz when i get the time. anything else to check? o_O
Old Nov 17, 2008
katzenjammer84's Avatar
katzenjammer84 is an unknown quantity at this point
I agree with speedfoo, sounds like the bearings may be at fault.
Old Nov 18, 2008
i dont really see how it can be a bearing though because the noise is blatantly coming from the top of the head.. i used my stethoscope everywhere on the motor: oil pan, block (each cylinder), head (each cylinder). no noise from oil pan, little noise from the block (my guess is its echoing from the head), and VERY loud noise from the head. maybe il post a video in a bit. regardless i will check it when i get the chance
Old Nov 18, 2008
speedfoos's Avatar
If you think it's coming from the head, then you need to check everything in the head. Valve lash (again), all the rocker caps, valves (seals, guides, seats) and so on. Honda engines transfer noise in strange ways sometimes so you have to check everything that moves and rule out what things aren't making any noises they shouldn't.
Old Nov 19, 2008
sounds so tedious. will do.
Dave Brabant
20
Oct 6, 2015 12:44 AM
MichaelLW
Sep 14, 2015 07:15 AM
Dave Brabant
Sep 12, 2015 08:39 PM
GritzNGravy
Aug 19, 2015 03:03 AM
tattedlariat
Aug 4, 2015 06:35 PM
