HELP! A/C blower fan is not working!
Old Oct 11, 2008
dalaw's Avatar
Bone Stock!
I need some help on troubleshooting wtf is wrong with my a/c blower fan on my 03 civic. It is not working. I checked the #12 fuse underhood and it is ok. Then I thought the blower motor itself is shot so I bought one off ebay. It arrived today and i plugged it in and that doesn't work either. The blower would start then stop immediately when I turn the key to "on". When I press the a/c button, the a/c compressor will not kick in either. What else is wrong?
Old Oct 20, 2008
02civic21's Avatar
Ricky Bobby style, IWGF
02civic21 is a jewel in the rough02civic21 is a jewel in the rough02civic21 is a jewel in the rough
Re: HELP! A/C blower fan is not working!
its your blower power transistor. its bad. you can get a new one or modify the old one. mod is way cheaper. the mod is you take the power transistor off and solder a 1kohm resistor between the open contacts. see pics answer courtesy of honda-tech member "jivi" heres the link http://www.honda-tech.com/zerothread/2041582
ID:	75070   Click image for larger version
Old Oct 22, 2008
dalaw's Avatar
Bone Stock!
ah, thanks man. I am gonna try the resistor trick tmrw. Hope its gonna work. I have tried replacing the blower motor and control switch unit and no luck. Good thing i didnt spend too much on those. Will let you know if it is really the transistor. Thanks.
Old Oct 24, 2008
02civic21's Avatar
did it work?
Old Oct 27, 2008
dalaw's Avatar
Bone Stock!
It works! Finally! I had been so frustrated and been driving without any air for the last month. The lowest resistor I found at Fry's was a 2.2 ohm so I welded two together in parallel to get an equivalent to 1.1 ohm and it does the trick. Can't believe its only a 50 cent fix! Props to you man!
Old Apr 28, 2010
MaxwellT's Avatar
MaxwellT is an unknown quantity at this point
Where do I get a 1k ohm resistor? looks like radio shack has them but what W do I get.? 1/2, 1/4, 1?
Old Apr 28, 2010
match it to the old ones. they look like 1/2 watt to me.
Old Apr 28, 2010
CraigW's Avatar
The correct fix would be using a 114 degree C thermal cut off device. That is what was in there originally.
Old Jun 23, 2010
MaxwellT's Avatar
I tried the soldering method and both heat and a/c still do not work. No fan at all. What should I try next?
Old Jun 23, 2010
CraigW's Avatar
What method would that be ??
Did you check the thermal cut-off to see if it was open ??
Old Jun 23, 2010
MaxwellT's Avatar
I tried the following:
I did not check the thermal cut-off. How do I do that?
Old Jun 23, 2010
CraigW's Avatar
The tco will look similar to a standard resistor, silver case 1 lead each end.
Check it with an ohm meter, should read near 0 ohms if o.k.
Not 100% sure of it's exact wiring configuration but you are putting 1k into a circuit looking for 0, & replacing a thermal fuse with a resistor.
Locate the tco & ohm it out.
Old Jun 23, 2010
CraigW's Avatar
http://www.honda-tech.com/showthread.php?t=2041582
This thread states 1 ohm.
It is a safety device to protect the transistor (like when people neglect cabin filters forever) The resistor will not provide protection.
Old Jan 25, 2011
danielw's Avatar
danielw is an unknown quantity at this point
sub...
mikemc422
Aug 9, 2018 05:41 PM
ORskier
May 3, 2015 12:54 PM
paulnguyen
Apr 20, 2015 01:33 PM
prowl
Apr 18, 2015 07:50 PM
Pir8pete
165
Mar 6, 2009 05:16 PM
