Ignition/Shift Box Lights
Old Sep 15, 2008
qijian's Avatar
I have a 2005 civic lx and the ignition and shift lights are not turning on. By shift lights i mean where the shift **** is at and not on the dash (P,N,R,D4,etc). and the ignition light is where you put the key in. I was wondering maybe a fuse went out or something. Any help?
Old Sep 15, 2008
CraigW's Avatar
Re: Ignition/Shift Box Lights
The light in the shifter section is a #74 wedge base bulb.
US LXs don't have a lighted key cylinder, only EXs.
Old Sep 15, 2008
qijian's Avatar
oh i see. is there a fuse to check before i try to find the bulb?
Old Sep 16, 2008
CraigW's Avatar
If your other illumination lamps are coming on (heater controls,defrost button) then the fuse is o.k.
Once you take the trim off the socket is on the drivers side, twist left to remove socket and the bulb pulls straight out. Small fingers help when putting socket back in.
stryder12
Jun 30, 2015 08:33 PM
MiniMi
May 27, 2015 01:57 PM
steveneddy
May 19, 2015 02:39 PM
smmahan
Apr 15, 2015 08:17 PM
cazminn
Nov 9, 2001 11:18 AM
