Aftermarket bulbs fryed wiring.
Old Aug 18, 2008
CIVIC9903's Avatar
CIVIC9903 is an unknown quantity at this point
Dear readers, this may be a simple answer to some but im not very familier with electrical so here goes, i had a set of aftermarket bulbs in my headlights and after removing one that burned out i noticed that the plastic part that presses onto the bulbs was completely melted, i have had a few different bulbs in the car before and never had this problem, however after looking over the bulbs i did notice that they were a set of 12v 100/90w bulbs unlike the stock 12v 60/55w. is my answer as simple as the fact that the wattage was just to high????
Also how much for a new cable that i melted, still works for now but i don't wanna leave it unfixed.
And for future reference is it a good rule of thumb to just buy bulbs that are the same wattage to avoid the problem in the future?????
Thanks for the help.
Old Aug 18, 2008
RallyeRedRider's Avatar
RallyeRedRider has a little shameless behaviour in the past
Re: Aftermarket bulbs fryed wiring.
I have seen larger gauge harnesses for this very purpose. I have used them on my truck (upgraded from 45 watt to 55 watt). I haven't looked for any for a civic before. You can buy a direct wiring harnesses (which will deliver even more power to your headlights) for generally around $100 or so. You can buy everything you need and make one yourself for $40-$50.
Old Aug 19, 2008
if they still work, then its just the connector and you can buy a hi temp version from auto parts store or autolumination.com
but its better to just make or buy a whole new harness in case the stock wires were damaged. they are too small anyway to run even the stock bulbs.
UltraHDGames
Jun 8, 2016 05:16 PM
cferry7
Oct 18, 2015 06:32 PM
Bruce2
Sep 27, 2015 08:45 PM
bhollie
Sep 22, 2015 11:08 PM
MamaBear2015
Sep 4, 2015 09:04 PM
