Timing Belt maintenance interval
Old Jun 14, 2008
GoSpeedGo's Avatar
GoSpeedGo is an unknown quantity at this point
Guys,
I have a 01 civic coupe EX at 154K definitely due for a timing belt change! The mechanic told me that he would replace the water pump as well as other dry belts. One more thing was the cam shaft gasket? All for $440 here in Southern Cal. Is this a fair price for such and what else if need be do I need taken care of at 154K? Thanks!
Old Jun 14, 2008
greeen01civic4d's Avatar
Re: Timing Belt maintenance interval
not a bad price for timing belt, cam seal, and waterpump with labor, id go for it, its about a 3-4 hour job if u know what ur doing
Old Jun 16, 2008
reddawnman's Avatar
reddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to all
Didn't I already answer this question in your other thread?
Very good price, I'd do it. It's possible you'll need a crank seal as well, but thats a bit more unlikely. If he's replacing the water pump be sure he flushes the coolant with DISTILLED H2O and Honda Genuine Coolant. Be sure he replaces the tensioner, it is about a $70 part but with 154K on the thing it is ready to die and it is just a PITA to open the whole works up again to do it later. Many mechanics skimp on buying the tensioner to keep the price down, be sure you get the tensioner set included in the job.
Standard maintenance as it appears in the owners manual for severe conditions applies in SoCal. Anything at any mileage up to 160K that has not been done should be done. Pay special attention to ball joints and other suspension gear as 160K is probably when things start to go assuming you are at original equipment - your shocks are most likely toast if they are original.
Not sure what else - just so many things in the manual that depend on if you've had them done or not.
Old Jun 16, 2008
GoSpeedGo's Avatar
Replaced OEM suspension with TEIN coilovers. Thanks, Red. I'll have to look into the tensioner you speak here of.
Old Jun 16, 2008
GoSpeedGo's Avatar
Thanks, Greeen.
mattdoc
Mar 14, 2017 12:10 PM
ChristinaVHH
May 10, 2015 03:51 PM
markp94
Apr 30, 2015 09:19 PM
rcolosi
Apr 29, 2015 07:48 PM
bsmiley
Apr 27, 2015 01:27 PM
