White Smoke, Car won't start
So if you have read any of my other posts since the past 3 weeks then you would know that I was trying to do a head swap and this and this and this. Well anyways... We finally got my old head back on and working and had to stick with that and the other day I noticed that it started clicking really bad coming from under the hood. So I took the valve cover off and started it up and noticed that the very first valve spring and rocker arm were not staying together so the spring would come back up and hit the rocker arm
Well I tried to fix it and thought I did. Well on my way to work yesterday it started making that noise again, but then all of a sudden just sounded like my engine fell out of my car and I had white smoke coming out of the exhaust and my CAI. I tried looking at it couldn't really see any damage on the top of the head, but when i tried to take my spark plugs out to look at everything the one that goes on top of the first cylinder will not move. No matter how hard I try I can not get it to budge and get out of there. If anybody can tell me why this crap is happening I'd appreciate it. Oh and as far as my car goes its an automatic and the only way it will start up is if I hold the gas in, but then immediately the rpms drop and it cuts off and smoke comes out of every single hole so please help
Re: White Smoke, Car won't start
theres a chance you didnt burp the coolant system when you put the old head back on and the airpockets would cause you to have less coolant than you should = hot = blown head gasket and even possibly a warped head. bummer.
blown head gasket, probably a water/coolant passage.
take out the spark plugs, and see if the plugs are unusually clean, usually means steam cleaned from the coolant/water
well actually the spark plug that goes in where the first cylinder is actually was melted to the head so yea I'm pretty sure that means the head is prolly F**ked to so it definitely sucks. I'm trying to convince my dad to take it off our insurance and take the tags off of it and then convince him to co-sign with me to get another decent car and just save up my money and go ahead and drop a K20 in it since it aint really going anywhere anytime soon
A head is 150-200 bucks used... just make sure there is no bottom end damage, get a used head and pick up a headgasket from honda. Your set. Why bother buying a whole new car- thats a huge waste of money.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
cooldan1
Apr 23, 2015 10:49 AM
SSMatey
Apr 13, 2015 06:09 PM
