trunk will not lock / latch will not fully engage
Old May 18, 2008
konstanting's Avatar
konstanting is an unknown quantity at this point
hello guys,
since yesterday, i cannot get my truck to properly lock/latch in place. when trying to close it the latch seems to engage half way, yet not enough to securely lock the trunk. you can just pull it back open, even going over a speedbump too fast will make it jump back open.
the latch itself seems to fully engage when i manually push it in with a key or so screwdriver to simulate the hook it would latch to, but it just will not work for the trunk...
any ideas & input is much appreciated.
KonsantinG
Old May 18, 2008
Re: trunk will not lock / latch will not fully engage
have you tried spraying some lithium grease in the latch? maybe its just getting stuck. or you can move the trunk rubber stoppers by turning them which makes the trunk sit lower or higher. prolly needs to sit lower to engage better. and finally the actual U-hook on the bottom can be moved up and down if needed.
Sep 26, 2023 06:44 PM
mjdiaz89
Jun 21, 2016 09:26 PM
mark1974
Jul 28, 2015 08:18 PM
bdrickybd
Jul 25, 2015 04:35 PM
17
Jul 23, 2015 11:48 PM
