Cant Read Codes - Odd Problem
Old May 7, 2008
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
Just some normal driving when the car when into limp, 01 coupe auto EX, so you start it it idles for a second w/ battery light on, u hear the pgm-1 relay click off, then the CEL comes on, does this about 12 times then, CEL stays on, car in limp, and no tach and coolant gauge shoots up and down (on/off)
SRS light is on but I think it's from the D/S seat belt holder is broken, so you really gotta hit it to get it in there.
Any ideas?
Oh and I CAN'T read codes, it wont establish a link. THANKS!
Old May 7, 2008
Re: Cant Read Codes - Odd Problem
ok I think it's related to the multiplex system, after the key is in for about 10-12 seconds the shift lock lifts as if your holding the break, and the gauge cluster gets an error
Old May 7, 2008
usually if you cant read codes, the ecu is toast
Old May 7, 2008
I'd love to swap it out for the other 3 we have, but this damn immobilizer.
Old May 7, 2008
greeen01civic4d's Avatar
its ur only choice, u gotta switch ecu's there is nothing else it could be
Old May 7, 2008
well i switched out the mulitplex system and it still does it, it's wearing down to that
Old May 20, 2008
d17civickid's Avatar
d17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of light
yea.. its the ecu.. same thing happened to me.
Old May 24, 2008
pmmed, thanks
Old Jun 1, 2008
I've been trying to find a new ecu, but nothing yet, (Im not sure compatability so Im just looking for the exact part #)
I just talked to someone who had the same problem and he changed his ecu but still has problems? Has anyone ever had this problem before?
Old Jun 1, 2008
It's a 37820-plr-a53, does anyone know whats compatable?
Old Jun 3, 2008
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
your problem would be the ecu. just bring your spare ecu to the dealer and have it programmed to your immobilizer. mine couldn't read codes either so the ecu is what i changed(old problem). now i have other electrical problems which i think would be the multiplex unit(new problem for 2 years). i'm having a hard time catching you on AIM. can you please email me about the multiplex unit?
Old Jun 3, 2008
Yea, I've been trying to hit you up on aim, I think I pmmed you my number too.
Pm me your email if you can't get me on AIM tonight.
Old Jun 3, 2008
New ECU is inroute
Old Jun 3, 2008
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
if it's not the ecu i got a body computer that is on the back of the dash fuse box.
also there is a empty plug on the front of the dash fuse box. i forgot the sequence but u can short that out and get body (multiplex) codes though the dome light.
on the service manual u download it's on page 22-273.
Old Jun 4, 2008
I actually own a service manual, I'll have to check on that thanks!
The only reason I think it is the ECU is because it isn't letting me read the codes, I really hope this is it, and I can be done with it.
Old Jun 4, 2008
DieMaster's Avatar
forgot to mention that the computer in the fuse box is forsale. it's only the computer as the fuse box it's self was half destroyed.
the empty plug is next to the yellow fake SRS plug that used to erase the memmory.
also some of those multiplex wires go to the ecu and the DLC( where u plug in the reader) so if that network is messed up it could keep u form reading codes too.
if your check engine light is on u can check codes the OBD 1 way. find pins 4 and 9 brwn/yel and brwn respectivly. short them together and turn on the ignition. the check engine light, airbag light, and ABS light (if it's a EX) will flash any codes stored. not evrey code will show up this way but it's a good backup and gives u a place to start.
mistermenphis22
Apr 3, 2016 08:06 AM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
bsmiley
Apr 27, 2015 01:27 PM
tylerginevan
Apr 27, 2015 12:29 PM
dooner24
Apr 14, 2015 07:51 PM
