Power Steering Fluid Leaking Into Car
Old Feb 10, 2008
m3mo15's Avatar
m3mo15 is an unknown quantity at this point
Exclamation Power Steering Fluid Leaking Into Car
Well basically my car has leaked some power steering fluid into the car through the hole where the steering wheel passes through the firewall. I can recall putting some fluid into the reservoir about a month ago, the fluid is still topped off it hasn't needed anymore since but my question is What could have gone bad, some kinda seal or something? What am i looking at here?
Old Feb 10, 2008
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
Re: Power Steering Fluid Leaking Into Car
dont see how it would come through the steering wheel where theres no fluid that runs through the hole
Old Feb 10, 2008
m3mo15's Avatar
In the engine compartment i noticed some oil under what seems like a rubber grommet or seal that meets the firewall, exactly where that hole is, maybe thats where it leaked into the car. If so, what could've gone bad...
Old Feb 10, 2008
LoneWolf's Avatar
LoneWolf is an unknown quantity at this point
^^^ Ive got the same ****. every time I jack up the front it seams to leak out through there some more.
it got so bad it ruined my carpet. & I had to remove it
Old Feb 10, 2008
m3mo15's Avatar
Damn, that sux, mine will be like that too i guess if i dont fix it. So did you ever take care of that problem? cuz if u did what was it.
Old Feb 10, 2008
LoneWolf's Avatar
its not fixed yet. but I did remove all the firewall padding that got soaked in PSF. I also stuffed a small towel in the hole where the steering rod passes through the firewall. & Im using that lucus PSF
Old Feb 11, 2008
m3mo15's Avatar
I was looking at the parts at this website >>> http://www.thehondapartsstore.com and the parts related to our issue lie in the P.S. Gear Box Components, what exactly do we need from there.. probably some ring sets or some seals, but this sat. i will find out, i'll let you know once i do .
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
mattdoc
Mar 14, 2017 12:10 PM
moorebl
Aug 29, 2015 08:39 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
