Rubbery Shift
Rubbery Shift
Guys,
I have a 2001 Civic Coupe LX - manual tranny with about 82K miles... it's been a trouble free all this time, but lately gear shift feels bit rubbery
(not the clutch pedal, but the stick shift itself). I checked the oil (next to brakes) and it's still within safe range - it doesn't grind or anything (yet), but it's taking some extra force to shift.
Do you guys think it's already time for a new clutch job???
Any tips on the OEM/aftermarket clutch service cost - I wouldn't mind going aftermarket if it's cost effective/performs better... Thanks for the tips!
(not the clutch pedal, but the stick shift itself). I checked the oil (next to brakes) and it's still within safe range - it doesn't grind or anything (yet), but it's taking some extra force to shift.Do you guys think it's already time for a new clutch job???
Re: Rubbery Shift
Check your transmission oil. If the shifts feel "rubbery" then that has nothing to do with the clutch fluid reservoir (which you checked). Your going to have to get under the car because there is no dipstick on 5 spds.
Re: Rubbery Shift
You could also try lubing around under the shifter itself where the metal pivots (and the cables too while you're in there). There's some DIY instructions on how to remove the shifter **** and the whole center piece to get at it.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
ricer_em2
May 11, 2016 08:09 PM
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
tommycanada
Sep 5, 2015 04:59 PM
