Car won't idle. plz help
Old Jan 8, 2008
  #31
oino's Avatar
oino is an unknown quantity at this point
Re: Car won't idle. plz help
Ok car starts. RMPs running high..
But I'm working on it.
Old Jan 8, 2008
  #32
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
we need pics amd vids please
Old Jan 8, 2008
  #33
ronaldo9's Avatar
Base map is only going to get the car started. I would NOT drive the car. Get that thing to a certified tuner ASAP!!!!! If you must drive it it's going to run shitty probably but don't mess with the EMS unless you know what your doing. You can do more harm then good seriously.
Old Jan 8, 2008
  #34
oino's Avatar
Ya I was going to change the timing. But I'll leave it.
I do need to lean it out some. Its running way to rich.
Old Jan 9, 2008
  #35
02BLKCIVIC's Avatar
just get it to the tuner^
Old Jan 9, 2008
  #36
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
damnnnnnn....! rich fother mucker. hey EMS sounds good; next day you buy it. sheeit. lol.. is this your first time modding a car? definitely seems like it. welcome to the scene!
Old Jan 10, 2008
  #37
oino's Avatar
No. Mostly simple mods. This is my first time modding to this level.
Ok Tuning done. not what I expected.
I'll scan the dyno result print outs and post the tomorrow.
Old Jan 10, 2008
  #38
speedfoos's Avatar
LOL - A gain of what 15-20hp? Yeah, N/A without high compression internals isn't going to give you very much more at the wheels.
Old Jan 10, 2008
  #39
02BLKCIVIC's Avatar
numbers please!!!
Old Jan 10, 2008
  #40
oino's Avatar
ok here it is.
He said I'd get about 5% more if I change the cat.
You guys think injectors would help too? if so what cc?
Corrent Engine mods:
V2 intake
Header
Catback
EMS
Cam gear
Stage2 Cam
Stage2 Cluch and 8lb flywheel
Other Mods:
Coilovers
Momo S.Wheel
17" Wheels/Tires
ID:	73456   Click image for larger version
Old Jan 10, 2008
  #41
ronaldo9's Avatar
TAKE YOUR CAR TO ANOTHER TUNER ASAP. Those numbers are too low man trust me. I made 124whp on the emangle. DJmota made 147whp with KPRO and you should be right up there in those numbers with EMS.
Also you should be fine with stock injectors. Ask your tuner what the duty cycle was but I bet they are no where near maxing out. Where was your redline on the dyno. With EMS you can bump it up and make some more power bc with that cam you can still make power above 7000rpms. Don't quit find out why the numbers are low and retune.
Old Jan 10, 2008
  #42
ronaldo9's Avatar
Oh and since you like spending money. You'd be my hero if you can replicate this build for the d17.
[youtube]http://www.youtube.com/watch?v=tgTlRL35hOs[/youtube]
Old Jan 10, 2008
  #43
oino's Avatar
ya right LOL!
Old Jan 10, 2008
  #44
oino's Avatar
So with the EMS and the Cam. Red line can me moved?
They were redlining starting at 7000.
He said I get Free retunes if I think somethings isn't right or I don't like it.
As long as I don't add any more mods.
Old Jan 10, 2008
  #45
ronaldo9's Avatar
Ya trust me man, the car has more in it. With the EMS you can tune it for w/e pump gas you are running. Full adjustability of ignition timing ect. How are the functions working on your car like the Idle and AC. Also, was the VTEC even working when you did the dyno pull. Please give as much details as possible. I always wanted an EMS and to see how it would run on an N/A car. Does it drive like stock? What are your air fuel ratios at cruise?
Old Jan 10, 2008
  #46
oino's Avatar
I haven't tried my AC yet.
The Idle is good.
Yes the Vtec was working.
It has a problem starting now. it cranks, cranks and cranks some more. Then starts.
Most definitely doesn't drive like stock anymore
Old Jan 10, 2008
  #47
99CivicDood's Avatar
99CivicDood is an unknown quantity at this point
Did you get any HP numbers? Or did they only give you Torque?
Old Jan 11, 2008
  #48
oino's Avatar
The second image has the HP. on the right 126.5
Old Jan 11, 2008
  #49
Oh, hah. I didn't realize there were two! What's the D17 normally put down?
Old Jan 11, 2008
  #50
lordhelmet's Avatar
Subscribed. You should definitely p&p the head and put higher compression pistons in.
Old Jan 11, 2008
  #51
oino's Avatar
ok this sucks and can't be right.
I didn't gain much at all.
I kept thinking that stock HP was 117.
Stock:
127HP SAE @ 6300 rpm; 114 ft lb @ 4800 rpm
Mods:
126.5HP SAE @ 5714 rpm; 119.9 ft Ib @ 5087 rpm
If Stock is 127 then I should be getting like 138 - 145 with all them damn mods
Old Jan 11, 2008
  #52
lordhelmet's Avatar
Don't feel bad. 127 is at the crank. You measured hp at the wheels. There is HP loss between the crank and the wheels.
Old Jan 11, 2008
  #53
02BLKCIVIC's Avatar
stock is 110 at the wheels.
i hit 116 at the wheels with a VAFC2.
***** way off.
O yah you can redline to 9k!
Old Jan 11, 2008
  #54
oino's Avatar
9k ?? I wish...
I need to go do some freeway driving.
See what she can do.
Old Jan 12, 2008
  #55
lordhelmet's Avatar
Get the rev limiter raised!!!
Old Jan 12, 2008
  #56
speedfoos's Avatar
Yeeesh. I wouldn't raise it to 9K without better rods. Our stroke is too long for that, you run a big risk of snapping one of the stock rods.
Old Jan 12, 2008
  #57
lordhelmet's Avatar
Cant he raise it to 8???
Old Jan 12, 2008
  #58
ronaldo9's Avatar
His cam makes power to 8,000 rpms but I still wound not raise it that high w/o building the bottom end. He may risk spinning a bearing or something else catastrophic. FYI I think Oscar (DJmota) raised his to 7,500 with KPro on the stock bottom end.
Old Jan 12, 2008
  #59
oino's Avatar
So I need build up the bottom end.
That will have to wait.
I think my next thing is going to be a new CAT and new hood.
after that. Need to pay off the CC some to do more.
engine has to come out to do the bottom end right?
What on the bottom end can be changed for my future shopping list?
Old Jan 12, 2008
  #60
ronaldo9's Avatar
FYI, ditch the cat all together its another restriction lol. Probably why your numbers are so low. As for the bottom end. You'd do right with some maxi light rods and higher compression pistons like 10.5:1 ratio. I would get some aftermarket rod bolts if you want to raise the redline and our stock crank should be sufficient. It might be economical to buy a cheap block from a junkyard and build that so you dont have any downtime. When its built you can just swap it out. Honestly I wouldn't bother building the bottom end. Ditch the cat, bump the redline to 7500, and retune. You'll get better numbers and save money.
