Car won't crank?!?!?!?!?
Old Sep 5, 2007
jakes01civic's Avatar
jakes01civic will become famous soon enough
Alright heres the problem. I have a 2001 civic ex. The other day it wouldn't crank so i replaced the battery after it tested bad, it started twice after i put it in then when i went to work the next morning. I was going to lunch and it wouldnt crank once again. so then i replaced the starter. it started like ten times after i replaced it. then i went to go take the core starter back and it wouldnt start. Then i was going to replace the battery cable but the one i got from autozone was the one for the car, but the one that was in the car has 4 wires. 2 of them run to the fuse box under the hood and then one of the other one runs to the starter and the other one goes somewhere else i couldn't see where it went. I thought that was weird. If anyone can give me any advice or can tell me whats wrong.
Old Sep 6, 2007
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
Re: Car won't crank?!?!?!?!?
I'm pretty sure nothing is wrong with your Battery Cable. If anything, just clean the contacts and you'll be good.
Sounds like a bad Alternator. If you can get the car started, check the voltage of the battery, if its anything lower than 13.5, your alternator is probably dead or you have a bad ground somewhere.
Before changing the starter, you should've checked the alternator.
Old Sep 6, 2007
f1n-5's Avatar
f1n-5 is on a distinguished road
bring it in to a honda dealer..
have them check the charging system, it only takes a minute or 2.
i work at toyota and its free of charge.. just ask the service advisors nicely.
Old Sep 6, 2007
thanks for the advice guys i'll check the ground first. if thats good then i'll take it to the dealer. thanks again.
Old Sep 6, 2007
Angry Re: Car won't crank?!?!?!?!?
Ok i cleaned the connections for the ground. It still won't crank! I'm about ready to roll it off a cliff. All i can think of now is the positive battery cable but it's ran weird. I have never seen a battery cable ran like it. It runs 4 wires, 2 to the fuse box , 1 to the starter and 1 somewhere else.
Old Sep 8, 2007
streetglower's Avatar
you need to perform voltage drop tests to determine if there is a connection issue. does it start if you jump it?
Old Sep 10, 2007
no it doesn't start when i jump it. I pulled the ignition switch to see if it was that. During that process I tried to start it with a screwdriver. It turned over a couple of times and then started. it wouldn't start when i put it back together. So i think i've narrowed it down to either the ignition switch or the ignition lock cylinder. Hopefully its the ignition switch because the lock cylinder from honda is 255 plus shipping.
Thanks for any advice you can give...
Old Aug 5, 2013
Nedak1995's Avatar
Nedak1995 is an unknown quantity at this point
I'm pretty sure that is just how honda runs its battery cables. Positive and negative connections both go to the fuse box then from there it goes to ground and to the starter. I am having the same problem with my 2000 civic si. All my dash lights and stereo work but it just won't start. There is a clicking sound coming from a big fuse in the fuse box under the good which I've tried to replace. I've tested the battery, starter, starter solenoid, ignitions switch, clutch relay switch, and the clutch switch and they are all fine. So for my car I've narrowed it down to just the fuze box. I would have a friend try and start your car. If you hear clicking in the fuze box like I do you probably need a new fuze and its a simple fix. If you are up to trying to check the starter and everything else I mentioned I have some tests that I can walk you through so you can come to your conclusion.
mattdoc
Mar 14, 2017 12:10 PM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
Trav_02civic
Apr 23, 2015 08:57 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
