strut bar installation messed up my alignment??
Old Sep 2, 2007
kcari's Avatar
i just had a strut bar installed in the front and back.
My alignment seems off this morning. Its a front wheel drive, so when I have my steering wheel straight on my car goesinto the left lane!! so I have to steer it slightly to the right to go straight. WHat the hell! i just got an alignment last saturday!! and it was fine.
Old Sep 2, 2007
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
Re: strut bar installation messed up my alignment??
sounds like you left something loose somewhere...i'd check all your nuts and bolts to be sure everything is tight. was there any point where your suspension was unloaded when installing the bars? i've heard with you may have to jack the car a bit to get some bars to fit properly, but i would think something is loose somewhere. esp if the car is pulling to one side...
Old Sep 2, 2007
kcari's Avatar
i had a shop do it for me... nothing seems loose. ive taken some pictures of the bars. One side's screws seem to be longer than the other.
They didnt jack the car up. They just removed the bolts, measured and adjusted the screws around...
Old Sep 2, 2007
you had a shop install a strut bar....
take it off and see if your alignment seems out of whack. nothing should have changed since they didn't even jack the car up to "close the gap" so to speak. start narrowing down the causes. failing that, a new alignment is in order.
Old Sep 2, 2007
kcari's Avatar
haha sorry im a noob i dont even know how to change the oil....
i let the shop take care of all that.
so does the installation look okay? how come one side is longer the other? Everything is tightened pretty well. I think they used power tools. An alignment would fix the issue you think?
Old Sep 5, 2007
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
^ just go back to wherever you got the alignment (since you just got it on saturday) and tell them its still not driving straight and they should do it for you for free.
Old Sep 5, 2007
Alpha 5's Avatar
I agree with nameless, the shop should redo your alignment for free.
I am having a hard time with the fact that you paid someone to install a stupid strut bar. How much did you pay them to remove then replace 6 nuts?
Old Sep 6, 2007
kcari's Avatar
does it look like its balanced correctly based on the length of how the nuts are positioned? I mean are they supposed to be balanced or can one end be longer than the other like how they installed it on me. Installation cost me 15 bucks, but thats because it was a friends friend's shop. I'll get the alignment again on saturday when I have time. thanks again
bluecoupe
Nov 28, 2001 08:21 PM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
CapYoda
Nov 20, 2001 10:36 PM
PlatnumBomb
Nov 9, 2001 01:11 PM
andylao
Nov 4, 2001 01:19 PM
