Diagnose my problem.
Old Jul 9, 2007
minorc's Avatar
minorc will become famous soon enough
My car squeels pretty loudly whenever im in reverse and it sounds like its coming from the driver side tire area, and whenever im driving there is like a metal on metal rubbing noise i hear coming from the passenger side tire area, could this be my brakes? Wheel bearing?
Old Jul 9, 2007
minorc's Avatar
Re: Diagnose my problem.
nobody want to take a stab at it?
Old Jul 10, 2007
speedfoos's Avatar
Ick. I'd pull the tires off and have a peek at the brakes. Either that or possibly your CV axles. I'd start with the brakes first though. When was the last time you had them replaced, mileage-wise?
Old Jul 10, 2007
minorc's Avatar
Got the car in May 2006, it was at 50k now im at 80K. perhaps my brakes are seizing?
Old Jul 10, 2007
TRIZ's Avatar
If the screeching sounds like a dying animal, check your belts.
Old Jul 10, 2007
speedfoos's Avatar
Quite possibly the brakes. If its coming from both sides, I doubt its the belts. Brake pads have little "squealer clips" which are wear indicators and when they start making noise you need to check your pads and probably replace them.
Old Jul 10, 2007
minorc's Avatar
the reverse squeel sound happens once n awhile, now the metal on metal rubbing/scratching sound happens all the f'n time, and it sounds like its getting worse..I dunno if this helps but i lowered the car about a month ago and didn't put a camber kit on yet...strapped for cash, also my alignment is off a bit i think. Any of these play a roll perhaps?
Old Jul 11, 2007
speedfoos's Avatar
No. Pull your damn tires and look at the brakes already. If you let them go too long your pistons will come out of the calipers and then you're really ****ed.
Old Jul 11, 2007
minorc's Avatar
Well i bought some brembo rotors and some new hawk pads so bye bye problem, thanks for the info dudes.
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
260000milesgoal
Sep 25, 2015 07:41 PM
IronFist
Sep 25, 2015 07:13 PM
rayaan_wasty
Sep 14, 2015 02:00 PM
