Clicking when accel?
Old Jun 16, 2007
Thrasher086's Avatar
Thrasher086 is an unknown quantity at this point
I have noticed for a few months that if I accel I can hear something click in the engine bay. I am not sure what it is but it will click once when I accel and if I left off the pedal then it will click again. Also when I go into reverse I hear it click once sometimes. It doesn't always happen. I think it has something to do with the way I accel to make the click. I have a feeling it may have something to do with the throttle body. Any Ideas?
Old Jun 16, 2007
Alpha 5's Avatar
Re: Clicking when accel?
sounds like CV joints......
Old Jun 18, 2007
I would think CV joints have to deal more with clicking when turning the wheel. This is one click (or maybe clank would be a better word) when i accel and when I left off the pedal I hear another clank.
Old Jun 18, 2007
Alpha 5's Avatar
This is true but when the CV's are too gone they will CLANK when you go strait then whe you stop. Also when you reverse and then stop. Just like U joints in a truck.
Old Jun 19, 2007
Yikes. Do you know the cost of replacing 2 front ones?
Old Jun 19, 2007
Alpha 5's Avatar
All you have are "Front Ones".
I don't know the cost, call your local auto parts store or do some searching.
I do know that the cv's for my accord cost about 60 or so apiece. If I install them. They are not that bad to install.
Old Jun 28, 2007
rishelle's Avatar
rishelle is an unknown quantity at this point
hmm... i think i have the same problem in my 04...
i didnt think it was the cv joints because i had a 95 civic with bad cv joints and the sound is not the same... but then again i think it is because this happens when i accel and turn.. and the olny thing i can think of is that boot popping
Old Jun 28, 2007
BLK03EX2DR's Avatar
BLK03EX2DR is an unknown quantity at this point
usually a noise on accel and then on decel it's either a tranny or motor mount. shouldn't happen with newer cars but it's possible.
Old Jun 28, 2007
02civic21's Avatar
Ricky Bobby style, IWGF
02civic21 is a jewel in the rough02civic21 is a jewel in the rough02civic21 is a jewel in the rough
check cables and check mounts if you can have someone else sit in the car and rev it while you locate the source of the noise
Old Jul 4, 2007
Does anyone think it may have something to do with the throttle plate? I had a feeling that maybe it is dirty and getting a little stuck which would cause the click noise. Like I said it doesn't always make this noise every time and the engine mounts to be bad sounds strange to me. Could be a possibility.
Old Oct 24, 2007
letsfightfelipe's Avatar
letsfightfelipe has a little shameless behaviour in the past
Ok Check your motor mounts I have the same thing going on in my car right now and its both, my motor mounts and torque Damper. I took it to AAA and they they ran the diagnosis for me.
Old Oct 24, 2007
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
HAHAHAHA
For someone that said he had NO idea how things work.......lawls!
Old Oct 24, 2007
I don't know how most things work, but I had the same problem. I looked around made a thread too was told what may be wrong and took it in, and in fact what I was told was the problem. So I decided to help this guy. I learned something new so stop being an *** to me.
Old Oct 24, 2007
FGCOUPE's Avatar
not a chance my friend...
there are peeps on here that dont care for me, and i dont care for your BS.
have a good one!
carid
Sep 28, 2015 10:13 AM
Skunkone
Sep 24, 2015 04:38 PM
charmon4815
General
Sep 22, 2015 08:00 AM
Juanb24
Sep 15, 2015 12:39 AM
Josh 1973
Sep 7, 2015 10:10 AM
