over heating when i stop moving
Old Jun 5, 2007
boosted1.7??'s Avatar
boosted1.7?? is an unknown quantity at this point
well i have a turboed 7thgen but it is over heating but only after i run it hard and then come to a stop like at a light. the car heats up real fast and will cool down fast if i start to drive slowly again. i changed the thermostat any ideas. i was thinking head gasket but i have no loss of power and it only heats after running hard then stop moving
Old Jun 5, 2007
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Re: over heating when i stop moving
my guess is head gasket
Old Jun 5, 2007
gsniper666's Avatar
gsniper666 has a spectacular aura aboutgsniper666 has a spectacular aura aboutgsniper666 has a spectacular aura about
i'd say headgasket and check ur coolant
Old Jun 5, 2007
yeah i my coolant levels were a little low but i have filled them. any body know where i can get cametic head gasket and some arp studs.
or have any better ideas on what else i should do while the heads off??
Old Jun 5, 2007
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
are your fans working properly?
Old Jun 5, 2007
D16Z6_owner's Avatar
D16Z6_owner is an unknown quantity at this point
try the fan before you go tearing **** apart. this happened to a friend after he had body work done and it would overheat while sitting. turns out the bodyshop didnt reconnect the fan.
Old Jun 5, 2007
0H3ebpEM2's Avatar
0H3ebpEM2 will become famous soon enough0H3ebpEM2 will become famous soon enough
check the coolant temp sensor and the radiator fan switch. The fan switch might be bad, causing the fans to not turn on. Otherwise its your headgasket. Buy a qualitry headgasket and some ARP headstuds
Old Jun 5, 2007
yeah the fans are working but i havn't done anything to my car in a about 9 months (besides basic stuff) and it just started happining. but i don't want to go and do the head and it not be whats wrong.. what about a water pump. i took my car to a local shop and he did a sniff test and at first the car passed then he ran the car and said it had a little co ( think thats what he said) so from his " knowledge" he said the h/g was starting to seep under boost . but i was not to convinced he was sure of what he was talking about. i just want to know why it dosent start heating untill the car stops moving...
Old Jun 5, 2007
idk if this will work but try running with no boost and see if it happens worse/better. due to my lack of turbo/ecu tuning knowlege it may not be possible
Old Jun 5, 2007
speedfoos's Avatar
ARP studs - get the ones for the D16Z6, part number is 208-4301. tunertoys.com has them for $93.90 + shipping. Cometics, I usually see them on Ebay, but I'm sure lots of other folks have them.
Sounds like your fans aren't doing their job when stopped or your radiator is "tired" (technical term). Are they both stock? Simple question but, when was the last time you changed out the coolant? Is the level low? Does it cool down when you peg the tach at say 3K (making waterpump turn faster)? Obivously air flow is cooling your car back down in a hurry when you're moving, so I would start with simple things first if you haven't.
I always have flashbacks to the lawnmower scene with "Carl" from Slingblade. When the two mechanics are scratching their heads over the motor and he goes to it, opens the cap, and says, "Needs gas."
Old Jun 5, 2007
lownloudnyc's Avatar
lownloudnyc is an unknown quantity at this point
I had this happen to my maxima and it was the radiator, it was cloged and only a smalll portion of the ratiator was cooling the coolent, replaced it with a new ratiator and it works perfect.
Old Jun 8, 2007
thanks i checked it out today and what i noticed is that the fans are comming on to late and they are only staying on for like 30 seconds and then going off but the car is still way hot. how can i fix this
Old Sep 11, 2007
Skylar1692's Avatar
Skylar1692 is an unknown quantity at this point
Same problem here.... Just started not too long ago... Any update on the cause of this? Thermo Switch?
Old Apr 30, 2010
hattori's Avatar
hattori is an unknown quantity at this point
I have the same problem. It is 97 civic dx. Water pomp and radiator is new. It cools down as quick as it warms up when I start moving. Sometimes it is ok, sometimes heat up. Do you think it is sensor or fan switch?
Any help appreciated thanks
Old Apr 30, 2010
BlueEM2's Avatar
Whachya lookin at?
It can be a few things...
Try the fans by simply turning your air conditioning on and seeing if they turn on.
If they do I'd start by trying to flush the air out of the cooling system... This is how.
Make sure the car is cold and not running.
Remove the rad cap and fill the radiator up to the top ( I bet it's empty )
Jack up the front of the car.
Start the car with the heat on FULL BLAST through the front vents and the rad cap removed and watch for air bubbles, the coolant will start to drop, as it drops down refill it. Let the car get to optimal running temperature (Where the gauge is supposed to sit)
What I do then is leave the rad cap off overnight, and when I get to the car in the morning fill the rad up the rest of the way. This just ensures all the air is gone.
Make sure you are filling up the actual radiator NOT the coolant reservoir
I bet you when they changed the water pump they did not bleed all the air out of the system
Then I'd go to Honda and replace your rad cap. Get an OEM.
If the problem persists come back here and you can do the next step
Old May 1, 2010
seoul4korea's Avatar
seoul4korea can only hope to improve
+1 on fans...
rayman7
Jun 20, 2015 09:48 PM
cruisers10
May 12, 2015 10:46 PM
cooldan1
Apr 23, 2015 10:49 AM
SugarRay
Jan 28, 2002 05:17 PM
