Annoying noise from "A Column"!
Old May 16, 2007
Azizst's Avatar
Azizst is an unknown quantity at this point
An annoying noise is coming from the right A column for a while. When I knock the plastic part (seen on the pics), it sounds like no clamp is holding it. There is no problem with the left one but the right one has a problem. I tried to feed it's back with some type of filling but it didn't work. Looks like there is a huge space on it's back.
How can I fix this? How can I pull this part out? Thanks!
Old May 16, 2007
CraigW's Avatar
Re: Annoying noise from "A Column"!
The fix Honda uses is strips of wool --->> http://www.geocities.com/pfeifferper...oardCorner.pdf
Old May 16, 2007
Azizst's Avatar
That's exactly what I need. Thanks!
nirvanaguy
25
Oct 26, 2017 07:26 PM
fvckbg
Sep 8, 2015 09:55 PM
Josh 1973
Sep 7, 2015 10:10 AM
junkyardguy
20
Sep 6, 2015 10:07 PM
tommycanada
Sep 5, 2015 04:59 PM
