When should Radiator Fan kick on?
Old May 4, 2007
CincyBlck2k1's Avatar
CincyBlck2k1 is an unknown quantity at this point
I know this might seem like a strange question... But I have had this problem that seems to be inconsistent.. Air is getting into my coolant system and causing the level in my reservior to rise... Now, the radiator, thermostat, rad cap have been replaced and it seems to be the head gasket, you'll prob notice I have a post asking about people's experiences when doing that... I knwo both my fan motors work... but I noticed in the garage that if I have the car idling, the temp guage never gets above half, but the fan never kicks on... now, If I turn on the AC, as soon as I hit the ac button, both fans on the radiator kick on at the exact same time... does that make sense?? I realize there are times when both may need to be running at the same time... but the rad fan I thought should kick in sometimes, but then again, if my temp isn't going above half on the dash guage, then maybe it's not needed... Any input is appreciated... Thanks...
Old May 4, 2007
2002civicLX2002's Avatar
The only Wyoming Redneck on here
2002civicLX2002 will become famous soon enough2002civicLX2002 will become famous soon enough
Re: When should Radiator Fan kick on?
i dont know the exact answer to this. but i do know that at idle your engine isnt getting hot enough to use the fans, especially if you just start it up and let it idle. im assuming both fans should kick on at the same time that makes sence to me. but wait for someone else to give you a better answer as i dont know the exact answer.
Old May 4, 2007
Thanks for the reply... yeah, it might not be getting hot enough... I have given it more throttle via the throttle body and held it prob at about 3k for 20 seconds trying to get it to kick on.. The car has never overheated, I am just double checking this before I proceed to replace the headgasket...
Old May 4, 2007
AmbulanceMonkee's Avatar
i'd have to check mine, but i would say it's normal for the fans to come on with the ac. as for them not coming on when it idles, i wouldn't worry too much about that until the temp guage shows it being really warm. my temp guage has to get to about halfway for the fans to kick on, too.
Old May 4, 2007
Syke Fu's Avatar
Syke Fu will become famous soon enough
If your car is just started and it idles for awhile, it will take some time for the fans to kick in. Now when you start driving it they will come on more often, like if your stuck in traffic or alot of stop and go stuff. As for the AC, the rad fans will come on about twice as much cause the engine is under more of a load.
cizsak
Jul 21, 2015 03:39 PM
Hqly2001
22
Jul 12, 2015 06:44 PM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
CivicsClass101
Jul 9, 2015 11:14 AM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
