name of this tool
Old Apr 4, 2007
95hondacivic's Avatar
95hondacivic is an unknown quantity at this point
name of this tool
Des anybody knows the name of tool to install a harmonic balancer for a 95 honda civic ex?
Also I install this piece last weekend but i didnt us any tool just a wrench.and i'been riding like this how safe is this?
thanks for the help!!!
Old Apr 4, 2007
ashokudu's Avatar
ashokudu is an unknown quantity at this point
Re: name of this tool
u can use an impact wrench for this? if u look at ur harmonic balancer it has a hole in the center for the bolt to go through and a hex concerntric with the hole. the special tool located on the hex so u can hold the balancer steady while u tighten the nut. u can ask ur dealer, autozone nor advanceauto carry it.
Old Apr 4, 2007
MURDOCK's Avatar
My cats breath smells like cat food.
MURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond repute
There is no need for a special tool for the install.
Use a torque wrench set to the specified torque value by Honda.
In order to keep the crank from turning while you tighten it you will need to hold the Balancer in place while you tighten it down.
You should be able to do this pretty easy now that all your belts are on.
Old Apr 4, 2007
i think its crank pulley removal tool
http://search.ebay.com/honda-pulley-...QQfkrZ1QQfnuZ1
Old Apr 4, 2007
MURDOCK's Avatar
I beleive his question was regarding install not removal, but you are correct on the name for removal tool.
Old Apr 4, 2007
well im assuming his car came with a crank pulley on the motor and he needs to take it off to put the new one on
Old Apr 4, 2007
MURDOCK's Avatar
Well your reputation as a Honda expert is probably well deserved I won't argue with that.
I don't have much wrench time on Honda.
I'll step aside.
Old Apr 4, 2007
thanks for your help!
Old Apr 5, 2007
ashokudu's Avatar
the crank pullley / harmonic balancer on honda is keyed. u do not need any puller to take it off, but u need the special tool from keeping the engine turning over or an impact wrench while u try to fasten or loosen the bolt.
i just used an impact wrench to tighten that bolt on a crv. i used some blue thread locker too. Cause every time i tried to use torque wrench the engine just kept turning over before i was able to get to the torque limit.
either way, the engine runs ccw and the bolt tightens cw. therefore the bolt gets a little tighter after u install it.
hopefully this clears all the confusion.
pilebuck13
Sep 21, 2015 10:45 PM
OptimisticWay
Sep 18, 2015 09:37 PM
AffliictiioN
Sep 16, 2015 02:21 PM
Fred65
Wheels and Tires
Jul 14, 2015 06:40 AM
