coolant leak
Old Mar 25, 2007
kLouD's Avatar
kLouD is an unknown quantity at this point
coolant leak
ive read many normal coolant leaks from overflowing the radiator or whatever but mine is weird. my civic is leaking coolant from under my glove department like drip drop and i definitely smell the coolant from the heater everytime i turn it on. any suggestions ?
Old Mar 25, 2007
MURDOCK's Avatar
My cats breath smells like cat food.
MURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond repute
Re: coolant leak
It seems like you have a problem with the heater core.
Either damaged hoses or small leak in core itself.
Old Mar 26, 2007
kLouD's Avatar
Re: coolant leak
is it possible to fix it myself?
Old Mar 26, 2007
MURDOCK's Avatar
Re: coolant leak
Well assuming thats even the problem yes and no.
The first thing you need to do is determine if its actually the heater core or one of the two hoses joined to the core.
If either of these components are the source of the leak then you can go about draining the coolant and making the repairs.
However I would suggest going to Auto Zone or the like and picking up a Haynes repair book for your specific car model.
In the case of the hoses it could likely be just a lose hose clamp or a small hole or slit in the hose, easy fix.
In the case of the heater core it would be a damaged vane or a solder joint has fractured. In this case you would need to take out the heater core and take it to your local radiator repair shop so they can presser test it to find the source of the leak then they will either solder or Epoxxy the hole.
But I am in know way suggesting this is the problem, to be honest with you I don't even know were the heater core is on a civic, I've never had a problem with it.
I hope this helps.
cukaracha
30
Jul 26, 2015 12:01 PM
Bounddyy
Jul 8, 2015 11:22 AM
ZILLA
Jul 5, 2015 05:24 PM
Causemo
Jul 5, 2015 06:42 AM
Causemo
Jul 4, 2015 07:11 AM
