Rear power window problem
Old Mar 20, 2007
tkrotchko's Avatar
tkrotchko will become famous soon enough
I just purchased a used 2003 sedan, and after I drove it away, I noticed a problem.
All 4 windows go down and up fine from the controls at each window, however, the rear two windows won't work from the driver's control. I tested the child switch, and it works as you would expect, I just can't control the rear windows from the driver's seat.
My reaction is that the driver's switch is at fault, but I'm not sure.
Any ideas? Is there a take-apart guide online or is it pretty self-explanatory?
Old Mar 20, 2007
CraigW's Avatar
There is a TSB about the "master window switch assembly" causing similar problems. You may be able to inspect the switch (some have said there are dark/burned areas on the switch)
Trouble I have had is getting the lower grip covers to release, It appears simple... But I can't get ANY of my 4 to release yet.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
got2kids
May 9, 2015 06:45 PM
bsmiley
Apr 27, 2015 01:27 PM
PimpBot5000
Nov 26, 2001 07:15 PM
