Car dies while in motion
Old Mar 8, 2007
ironhide's Avatar
ironhide is an unknown quantity at this point
I have wierd problem that is generally infrequent, but seems to be increasing in frequency of late. My car is currently with Honda for a diagnosis but it has been 2 days and they can not work it out because they are unable to replicate the problem.
I'm driving at normal speeds and all of a sudden the engine cuts out as if I stalled the car. If I immediately try to start the car, the engine turns over and sometimes fires up but them immediately dies. Generally if I try this a few times and can't get it going, I turn off my car, take out my key and wait a few minutes. I am usually then able to start the car and away I go. The problem may not occur again for weeks.
It has happened 4-5 times over the last two months or so, but the last two days it cut out on a few times. I have drop it at honda but they are at a loss.
I don't know if the last two days being quite hot has anything to do with it. My temperature gauge seems is fine.
Personally I'm thinking it is something electrical. Alternator is fine, Battery is fine. Could it be immobiliser? Key? Failing sensor?
It's not throwing any ecu codes either.
Any ideas on things to get honda to check. They are at a loss at the moment too.
Old Mar 8, 2007
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
I would say Crank Sensor. It doesn't throw a CEL if there is an issue.
Does it immediately cut off? or is it a slow sputter, then it dies.
Old Mar 8, 2007
ironhide's Avatar
Crack senor was my line of thinking too.
It dies immediately when I am driving.
When I try to start immediately after it dies, then it sometimes fires up and sort splutters and dies. If a wait a few minutes it is fine and starts fine.
Old Mar 8, 2007
ironhide's Avatar
Old Mar 12, 2007
mani_is_kool's Avatar
mani_is_kool is just really nicemani_is_kool is just really nicemani_is_kool is just really nicemani_is_kool is just really nice
hmmmm ... strange ..
Sometimes its the most craziest thing u can imagine ... Did u check ur Terminals ??? any signs of excessive corrosion ? ... Stock batter ? did u check the battery fluid ???
If everythings fine and it still does it ... and IF YOUR STILL UNDER WARRANTY !!! Get ready for an 06 CIVIC SON :-p Lemon Law protects you in this case ;-)
Old Mar 12, 2007
ashokudu's Avatar
ashokudu is an unknown quantity at this point
hate to say this, does ur civic have a electronic key, one of those where u can not replicate them at walmart, then it may be that cutting the ignition off cause it lost its signal. its just my thinking.
Old Mar 12, 2007
jan3sobieski's Avatar
jan3sobieski is an unknown quantity at this point
Had the exact same thing
Not sure whether you have an automatic or a manual, but i have a manual and had the exact same thing happen to me a couple of years ago.
It got to a point where the car would not run at all. It would just die right away. The solution seemed to be an old program loaded in the car computer. I bought my 2001 civic in november 2000. It was probably one of the first one out of the factory. It seems it still had some old program, don't ask me. They flashed it, meaning loaded the newest one they had at a dealer and all was fine since then.
Old Mar 12, 2007
CecDogsVTEC's Avatar
Member
CecDogsVTEC is an unknown quantity at this point
Mine cut out today and wouldn't even start back up. Could it be a fuel pump? It was towed to Honda to get looked at tomorrow. Ill let you all know.
Lata
Old Apr 9, 2007
eekicks's Avatar
eekicks is an unknown quantity at this point
Re: Car dies while in motion
I have had my engine cut out on me and alson not start up. This problem is serious and seems to be reoccuring. I have had it at the dealership with no success on any findings?
Old Jan 8, 2010
sacredpalm's Avatar
sacredpalm is an unknown quantity at this point
I have the exact same problem with my 99' Honda Civic. The occurances are becoming a bit more frequent now. Let me know if Honda finds the problem
Old Jan 8, 2010
africanoboomer's Avatar
africanoboomer is an unknown quantity at this point
i had the same problem too, dealership could not find anything wrong and they ended up just putting a new engine, which was not the smartest idea but i had given up and had no choices.
McD
Apr 29, 2015 03:50 PM
Switch BL4D3
23
Apr 24, 2015 06:57 PM
twtron
Apr 17, 2015 12:09 AM
McD
Apr 16, 2015 10:46 AM
CiViCPrAnInG2k1
Detailing
Nov 9, 2001 08:34 AM
