Shifting to reverse
Old Jan 7, 2010
T-Funk's Avatar
T-Funk is an unknown quantity at this point
Shifting to reverse
Ok i have a manual 02 ex and i have been having troubles shifting into revers and having the gear actual grab it still works but it takes a while i have to jiggle it around and I can pull my stick as hard as i want and it just does not want to go into reverse please don't say its my tranny...
Old Jan 7, 2010
Zzyzx's Avatar
Autocross Junky
Re: Shifting to reverse
Well.. it could simply be the gears misaligned. Does it happen all the time or just occasionally?
Try putting it in neutral and letting off the clutch before you continue on going in to reverse. (to get the input shaft spinning again)
Old Jan 7, 2010
izotop's Avatar
izotop is an unknown quantity at this point
Mamamia! I know what you're talking about and don't get desperate!
First thing you gotta know is that first and reverse gears do not have synchros on our particular car. Practically speaking, that means that you have to be completely stopped before you shift into these gears, or you may damage your transmission on the long run.
The absence of synchros brings something else. If the reverse gear, which is not part of the two main shafts, is not aligned with the gears situated on the main shafts, it simply won't go. Don't put any extra strength, don't smash it into gear and above all, don't cry. This is how these transmissions are made. Bad design? maybe. But we have to deal with it.
Now, it is really important that you do not over force it into gear or you could otherwise damage the transmission permanently.
1) Put it in neutral
2) release the clutch for 2 seconds
3) press the clutch again
4) try to get it in reverse
If that doesn't work, try it again over and over.
If that still doesn't work, it might be time for a rebuild. Maybe it's been mistreated to much before...
Old Jan 8, 2010
T-Funk's Avatar
Dang ok well i have tried that but it also does it when i am just sitting still.... is there a way to put in synchros
Old Jan 8, 2010
Awjvail's Avatar
Awjvail is an unknown quantity at this point
My car does that occasionally... usually, when I let off the clutch and reapply, it goes in fine.
It also does it going from Neutral to 1st.
Old Jan 8, 2010
BlueEM2's Avatar
Whachya lookin at?
I don't think there is a way to put in synchros... If there was it would be incredibly complicated and expensive. What I do is what izotop said. Start releasing the clutch without being fully in reverse, and once the input shaft starts spinning, it goes in well. That's my recommendation anyway, even though it's the same as his
Old Jan 8, 2010
wow that would drive me crazy, glad i have the auto. even tho its breaking too haha
Old Jan 9, 2010
BlueEM2's Avatar
Whachya lookin at?
It's really not that bad. Just takes a little bit of getting used to
Old Jan 9, 2010
izotop's Avatar
Even if you're sitting still, if the gears are not aligned...well...they're not. What you want to do then is trying to get them aligned using the procedure that I described or the one described by tbohar. There is no big deal there.. Just get used to it.
My former car (Saturn Ls1 2000), an old failed whale, never did that because the reverse was synchronized. At first I was pissed with the Civic, but then I realized that... - This is how they're built.
Old Jan 9, 2010
BlueEM2's Avatar
Whachya lookin at?
It's also one less thing to go wrong.
Old Jan 9, 2010
T-Funk's Avatar
Ya i do suppose well i guess it will just have to practice lol thank you very much for your guys input
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
ricer_em2
May 11, 2016 08:09 PM
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
