Trouble Starting in Cold Weather
Old Mar 1, 2007
savedadogs's Avatar
savedadogs is an unknown quantity at this point
Hi All,
I have a 2004 Civic EX Coupe. I live in Los Angeles, so usually the temperature is pretty moderate (warm). However, at night the temperature drops to 40-50 F. When I try to start my car when it is around this temperature, it doesnt start, I have to try like 2 or 3 times before it will actually turn over...it seems like a spark is not happening or something. Can anyone help? I took the car to the dealership last year (around winter) and they wouldnt do anything because they could not reproduce the problem.
Thank you.
Old Mar 1, 2007
EastBayStuntN's Avatar
EastBayStuntN is an unknown quantity at this point
im not sure if this is related to your specific issue. but my 03 auto ex would struggle to turn on during a cold start. after upgrading the ground wires to give it better eletrical current, it never hesitates to start anytime of the day. i did this mainly for stereo needs but i noticed this on the side after a year or so.
some 4gauge wire and terminals will only end up around $15 and 45min of your time.
Old Mar 1, 2007
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
if it happens again, try turning your radio/electrical components off before starting and see if it works. Check your battery voltage at night to see if you have enough, its much more important that you see if you have enough CCA (cold cranking amps)
^^ or thats also a good idea too
Old Mar 1, 2007
HotShotMedic's Avatar
HotShotMedic is an unknown quantity at this point
i have the same problem in cold weather but my battery is near frozen when it happens i think. i posted a question about which battery to upgrade to but didn't get any responses. upgrading my ground wires is definately on my to-do list this spring.
Old Mar 3, 2007
Scroder's Avatar
Scroder is an unknown quantity at this point
What exactly are you all doing when your saying you upgrade the wires? I have this problem too---are you doing the "big 3" like the car audio folks do or something else? Thanks,
Dave
Old Mar 3, 2007
03logic's Avatar
03logic is an unknown quantity at this point
upgrading the ground wires is replacing the stock electrical grounds with larger wires and sanding away a small portion of paint for a better electrical ground. there is a DIY on here somewhere but I can't find it through the search function.
Allecr3
May 22, 2015 01:24 PM
jc33312
May 12, 2015 03:17 PM
tylerswire
May 6, 2015 12:16 PM
gabrown2
Apr 11, 2015 08:22 PM
black2k1vtec
Dec 6, 2001 09:49 PM
