side motor mount
side motor mount
I had a lot of vibration in the cabin of the car, i realized i had two broken motor mounts. The front one i got just fine. But the side motor mount where your windshield washer fluid goes i had a little problem. I got everything off and the new one on, i got two main bolts screwed down on the engine side, but i couldn't get one out of three bolts screwed down on the rubber side. I actually got it stuck cause the bracket and the hole is a little off so its stuck at a angle. if it comes out and maybe zip tie it, or leave it stuck will the motor mount be fine, since its mostly all tight? Please someone respond soon thanks!
Supramk3
May 11, 2015 07:55 PM
