Vearing to the left bad , until i hear the pop...HELP
Old Jan 18, 2007
marcuse's Avatar
marcuse will become famous soon enough
ok so this has just started happening in my 02 ex coupe. ill start the car drive down the road let go of the wheel and it will slide into the other lane within a second , very quickly. so im like wtf everything is balanced alignments alright whats going on. So i steer quickly (jerking) the wheel to the right and i hear a pop from the front right of the car then i let go and everything is perfectly back to normal
im dropped on HR springs and stock struts (could be it) im thinking tie rod?
HELP PLZ.
Old Jan 24, 2007
marcuse's Avatar
bump , need insight
Old Jan 24, 2007
AmbulanceMonkee's Avatar
Stick your head under there. Does anything look loose/worn??
Old Jan 24, 2007
tfnaaf's Avatar
BLDNPSI Mod
yup sounds like something is lose or worn out causing a sift in camber/caster
Old Jan 24, 2007
marcuse's Avatar
checked the tie rod while turning everything is smooth , i dont really understand it its only at 40+ mph..
Old Jan 24, 2007
tfnaaf's Avatar
BLDNPSI Mod
check lower control arm bushings, lower ball joints, upper strut mounts, the 2 bolts from knuckle to strut.............
Old Jan 24, 2007
2002civicLX2002's Avatar
The only Wyoming Redneck on here
2002civicLX2002 will become famous soon enough2002civicLX2002 will become famous soon enough
you say your lowered? then your springs might not be set right and the "popping " noise your hearing might be your springs popping. to check your tie rods jack up the front of the car and shake your tires back and forth and have a buddy look for anything moving abnormaly, then shake it up and down, very hard and check your ball joints and bearings.
Old Jan 24, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Drift sounds like an alignment is needed. I'd be checking the crash bolts for being tight, then checking that the shocks are indexed. One of those 2 is likely the pop/slam noise.
Old Jan 26, 2007
marcuse's Avatar
I know how to check the tie rod , and i already stated its not that. its also not the popping from the springs because we all know that when lowered on springs its common for that pop to happen when your not moving. im thinking its just in need for a front end alignment which im going to get today.
Old Jan 26, 2007
BCCentaur3's Avatar
BCCentaur3 is an unknown quantity at this point
Do you have a camber kit on there?
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Poopies
Apr 20, 2017 11:36 PM
GH04si
Apr 15, 2015 08:13 PM
supercivic01
South
Nov 30, 2001 11:27 AM
StLVtec
Nov 14, 2001 09:22 PM
