4th spark plug coil oil???
Old Dec 11, 2006
edtech's Avatar
edtech is an unknown quantity at this point
I was checkin my spark plugs to see how the car was running, and found a nasty surprise. I pulled the 4th spark plug coil out to find a small pool of oil sitting at the base of the spark plug, and also the little rubber thing at the end of the coil was ripped off and stuck in the spark plug hole. Is there some sort of tappit gasket? or is this included in a valve cover gasket? if I take it to the dealership will they bend me over? Is it not too difficult of a job?
thanks any help is much appriciated.
-matt
P.S. My car still runs and drives fine........
Old Dec 12, 2006
goodtimes's Avatar
your piston ring might be shot how many miles do you have on your car.
Old Dec 12, 2006
edtech's Avatar
uhhh
Well the car isn't burning any oil, I don't really think it is anything internal. Just to clarify the oil is on the outside of the sparkplug, the little pool of oil was there before I pulled out the spark plug. It is in the little hole that the spark plug coil goes into. I think that some oil is leaking by the coil pack.
Oh and I got 135,000 km on my car.
Thank you for responding,
-matt
Old Dec 12, 2006
streetglower's Avatar
you may have a spark plug tube seal that is faulty causing the leak. if you remove the valve cover you can replace them.
Old Dec 12, 2006
edtech's Avatar
ok, I will have to look into it pretty soon. Just removing the valve cover shouldn't be too difficult.
Thanks for the help!
matt
Old Dec 12, 2006
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
Make sure when you get the new valve cover coil gaskets you but them in and put the cover on in the correct tighting sequance and torque.
docmartin14
Jul 30, 2015 11:26 AM
danace99
23
Jun 28, 2015 08:49 AM
mrohitredd
May 28, 2015 10:03 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
MikeyBoy
Jan 26, 2002 06:45 AM
