lock assembly or actuator?
Old Dec 10, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Question lock assembly or actuator?
Just wanted to double check with you guys but,
My driver side door lock wont do anything.
I press it down with my finger and it wont lock...
even when I use my remote.
is it the lock assembly or just the actuator???
thanks
Old Dec 10, 2006
streetglower's Avatar
well the actuator is part of the lock assembly, so either way if you order a new lock assembly, you get that with a actuator.
Old Dec 10, 2006
02BLKCIVIC's Avatar
thank you sir!^
how the hell do I get the damn handle off that bar
when im removing the door pannal???
Old Dec 10, 2006
not sure what you mean
Old Dec 10, 2006
greeen01civic4d's Avatar
drivers side door lock will lock if you pull out the handle while pushing it down, its a safety feature, but i have the same problem on my 02 coupe, i think its the actuator, as far as pulling off the door panel, there is a removable panel under the handle that pops off, revealing two screws to get the door panel off
Old Dec 10, 2006
02BLKCIVIC's Avatar
I the entire door pannal just barly hanging the only thing keeping that is left attached is the door "handle" and the "bar" or "rod" is connected to it.
How do I get the door handle off? After I remove the two screws it still connected to the door by a rod?
Help!
Thanks!
Old Dec 10, 2006
pull the panel off that is behind the actual handle, there should be a small panel that hides a screw, and then it should pull through the door panel
Old Dec 11, 2006
just remove the rod from the handle.
Old Dec 11, 2006
yea that too
Old Dec 11, 2006
02BLKCIVIC's Avatar
ill take pics.
because i cant get the rod off.
I also cant find the screw behind the door?
I just have the pannal hanging and the only thing holding it there is the handle.
Old Dec 11, 2006
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
As per the Service Manual: remove the small panel behind the handle and the 2 hidden screws, pull the inner handle forward and out half way, then disconnect the inner handle rod and power lock switch connector.
If you need the pic let me know and I can scan it and email it to you.
Old Dec 12, 2006
if the only thing holding the panel is the handle, remove the handle. a little clip holds the rod to the handle.
Old Dec 12, 2006
02BLKCIVIC's Avatar
the clips are the part I cant remove,
But I will try again this weekend.
Thanks Bob for the pics from the service manual.
fvckbg
Oct 20, 2016 07:37 PM
aaronmechanx
Sep 14, 2015 08:45 PM
nixyfior
Sep 14, 2015 08:32 PM
rayaan_wasty
Sep 14, 2015 02:00 PM
