Minor grinding between gears
Old Dec 6, 2006
twinbo's Avatar
twinbo is an unknown quantity at this point
I have a 2001 lx coupe with a 5 speed and high mileage. I am starting to notice that shifting isn't smooth anymore and sometimes the tranny pops out of second gear. Overall it just feels like **** compared to 3 months ago. It is orginal clutch and shifter assembly. Is this the beginning of the end for my tranny or could it be that my clutch is starting to show its age? Any help would be great
oh btw. i have changed the transmission fluid and I don't drive the car that hard...much
Old Dec 6, 2006
BCCentaur3's Avatar
BCCentaur3 is an unknown quantity at this point
its your transmission, all those signs point to tranny issues. Same thing happened to me. If i were you i'd go out and gte a used tranny vs. getting it rebuilt, because i went the route of getting the rebuild and basically got raped in the butt hole.
Old Dec 7, 2006
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
You can try a tube of Moly grease in it first, before you rebuild it. My car shifted like crap since new. One tube of moly and a few hundred miles later it shifts like butter. And continues to do so. I had originally let Honda change the gear oil, and it actually made it worse. I don't really care what people say about only using Honda this or Honda that. In the case of the 7th gen transmissions, I dis-agree.
Old Dec 8, 2006
johnnyboy5000's Avatar
johnnyboy5000 is an unknown quantity at this point
How/where do you use Moly Grease? What is Moly Grease?
Old Dec 13, 2006
twinbo's Avatar
Yeah i am interested in this Moly grease. Does it have to be done when the tranny fluid is changed because i just did that
Old Dec 15, 2006
Frost's Avatar
Frost is an unknown quantity at this point
Here's my suggestion for the 7gen manual transmission: Dump the Honda MTF
and use Redline MTL instead. My 05LX was notchy from 6 miles on the OD until I got so sick of it & dumped the MTF at 3500 miles for Redline MTL.
Within 50 miles all my complaints about the transmission were solved!
Honda says to change the 1.8 qts of MTF what? every 60K miles in normal service? This stuff is documented to be beat at 20K miles! I wonder how many of these transmission problems would be avoided with a better quality oil changed at a reasonable interval. As a follow up I changed the Redline at 20K miles and it looked good: no metal wear particles or junk in the fluid. Shifting is smooth & notch free even when it's cold. I only have 26K on this car so I'll follow up at 100K & let you know how it holds up....
I also use Redline in an 88 Accord for many trouble free years & miles.
I would not put grease in any transmission!
Old Dec 15, 2006
tinman's Avatar
You can use lubro moly gear lube, or redline MTF. Nothing wrong with redline at all.
The moly grease doesn't harm anything in the transmission, btw. There is just too little to even thicken the oil. It's just the moly you want.
Doesn't really matter. Both work fine, but all gearboxes are different. One may work better than the other.
Old Dec 15, 2006
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
i think you just need a tranny fluid flush. After i did mines, it felt so much bettaa
Old Dec 15, 2006
01EXGUY's Avatar
01EXGUY will become famous soon enough
my previous civic done that and it turned out to be the synchronizers in the tranny. mine done it going into fifth gear and would always pop out of that gear. had to get a tranny from a salvage yard cause it wouldve cost about $1000 to fix it
Old Dec 15, 2006
mr.rowdy's Avatar
mr.rowdy is an unknown quantity at this point
I have an 01 lx coupe and my tranny did the same thing.. It was the sincros going out and it was 2nd gear.. I'd be prepared to get a new tranny..
Old Dec 16, 2006
2002civicLX2002's Avatar
The only Wyoming Redneck on here
2002civicLX2002 will become famous soon enough2002civicLX2002 will become famous soon enough
ya, with the gear popping out, that is not a fluid issue, it is a synchro issue. this could have been prevented with a good tranny fluid, maybe. but, 7thegn trannys suck, no arguments.
nirvanaguy
25
Oct 26, 2017 07:26 PM
wingsfan19
Oct 1, 2015 03:45 AM
siliconvalley
Sep 15, 2015 09:48 PM
Josh 1973
Sep 7, 2015 10:10 AM
tommycanada
Sep 5, 2015 04:59 PM
