Transmission Issue During Cold Startup
Old Nov 27, 2006
Espo's Avatar
Espo is an unknown quantity at this point
This is a very strange issue that happens only if the car has been sitting for a while. It also only happens in cold winter weather and has never happened during the spring or summer time.
When the transmission is placed into drive it makes a hard bang and it takes a bit of gas to get the car moving. Once the car is in motion the transmission is totally fine and shifts smoothly. If I park the car for a short period of time the transmission engages smoothly. Only when parked for an extended period of time ie.over night, does the issue arise.
I have read a few other boards and it seems that various other Honda owners have had this problem. Im wondering if this is something I should worry about?
Old Nov 27, 2006
streetglower's Avatar
have you checked your fluid level? it sounds as if the level is low.
Old Nov 27, 2006
Espo's Avatar
Sorry, I should have mentioned I checked the fluid level and the fluid was replaced about 10,000k ago.
Old Nov 27, 2006
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
what kindve fluid did you use? OEM honda?
Old Nov 27, 2006
Espo's Avatar
Yep, OEM Honda.
Old Nov 28, 2006
CraigW's Avatar
What year ?? How many miles ?? How many tranny services have been done over the life of car ?? Have you contacted the dealer or Honda about this issue ??
Old Nov 28, 2006
Buds302's Avatar
Buds302 will become famous soon enough
how cold does it get when this happens? i had a 88 accord that did this. it turned out that the fluid just got cold and thickend up like normal motor oil does when its cold. causing the pressure to be really high in the tranny. therefore slamming the first gear. it was a common problem in the automatic honda transmission. ive met several people with the same problem
Old Nov 28, 2006
Espo's Avatar
2002
56,000miles
Tranny Flush @ 40,000miles
I havent spoken to the dealer about it yet.
Originally Posted by Buds302
How cold does it get when this happens?
Below 14F -10C
Old Nov 28, 2006
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
thats normal when its that cold... just baby your car till your engine warms up a bit.. dont rev the hell out of your car to get the temp up... just start it.. wait about 30 seconds.. put it in gear and drive off slowly.. take it nice and slow for the first few hundred yards.. if you park in a parking lot make a few laps and then hit the road.. after a mile or see your car should be warming up... once you see the temp gauge go up drive like normal...
cars are like people.. when its cold it takes a few minutes to get going...
the clunk is normal.. its due to your fluids being all sorts of cold.. they do make trannyfluid thats made for super cold temps.. however you dont really need it if you give your car a few minutes to warm up..
mikemc422
Aug 9, 2018 05:41 PM
cruisers10
May 12, 2015 10:46 PM
jc33312
May 12, 2015 03:17 PM
markp94
Apr 30, 2015 09:19 PM
alexkharden
Apr 23, 2015 07:13 PM
