Stuck Speedometer!!
Old Nov 18, 2006
zachpolo's Avatar
zachpolo is an unknown quantity at this point
Stuck Speedometer!!
So I got my car aligned and a FULL set of new tires, and when driving back from the shop, I noticed its stuck at 40... No matter how fast I go, It stays at 40..Any ideas how to fix?
Old Nov 18, 2006
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
take it back to the shop and tell them to fix it......
Old Nov 18, 2006
FALKEN's Avatar
Civicforums Junkie
try this:
1. push/hold the trip button.
2. turn the lighting switch on.
3. turn the ignition switch on.
4. (within 5 seconds) turn the lighting switch OFF, then ON, and OFF again.
5. (within 5 seconds) release the trip button
6. push and release the button 4 times repeatedly.
this starts the gauge cluster self diagnostics...
the beeper will sound
the lights will flash
the LCD will flash
the needles will sweep
if they/one does not sweep properly, replace the cluster.
to exit diagnostics, turn off the ignition.
Old Nov 18, 2006
puidokas's Avatar
puidokas is an unknown quantity at this point
Have you ever opened your cluster for any reason?
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
260000milesgoal
Sep 25, 2015 07:41 PM
MamaBear2015
Sep 15, 2015 09:35 PM
nixyfior
Sep 14, 2015 08:32 PM
