accessory socket help?
Old Nov 14, 2006
bloodhound248's Avatar
bloodhound248 is an unknown quantity at this point
hey guys i know this will sound incredibly stupid but i dont understand it at all. i recently went on a trip upstate and a friend of mine brought his ipod along for the ride. the power adapter fit perfectly into the accessory socket going in. now for some really weird reason its not budging no matter how hard i try to get it out. it seems like its just completely stuck in the power socket. has this happened to anyone before/how on earth do i get it out?
Old Nov 14, 2006
nj_represent's Avatar
nj_represent is an unknown quantity at this point
Pull that panel off, and pry down the tabs that apply pressure to the wall, it should slide out.
Old Nov 14, 2006
any advice on how to take that panel off?
Old Nov 14, 2006
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
wrap the tip of a flathead screwdriver in tape.. cram it behind the pannel and yank like hell..
or.. if you have one or two empty accessory slots open just pop the caps off (with a flathead screwdriver).. shove yer finger in the holes and yank like hell..
theres 4 clips holding the whole thing in place.. heres a pic
Old Nov 14, 2006
CraigW's Avatar
This may help also. The plastic is easy to scratch.
File Type: pdf
Old Nov 15, 2006
thanks alot guys that helped alot
Old Feb 20, 2007
savedadogs's Avatar
savedadogs is an unknown quantity at this point
The same thing happened with my navigation power adapter...it was just plain stuck. I had to remove the center console in order to get to the back of the lighter. If you have a 2004-2005 civic, you cannot simply rip off the lighter/console part as shown in the above pic, you have to remove the console. After removing the console, I had to use a flat-head to free the adapter...it seems that the civic lighter socket just plain sucks...this is the second time this happened...first time was with a portable tire inflator. That time I pulled so hard the adapter broke.
h4ldol
Apr 24, 2017 08:16 PM
Styven Szastur
Sep 23, 2015 05:26 PM
Bricoleur
Sep 9, 2015 12:23 PM
