Battey Voltage
Old Nov 12, 2006
thewal's Avatar
thewal will become famous soon enough
Battey Voltage
Hi Everyone,
I have a 2003 civic with a sound system in it. 10'' sub 2 amps one capacitor,
etc...
I just purchased a new Odyssey battery and I was wondering, is it normal that when the car is not running the battery voltage is at 12.35 volts?
when its running its charging at 14.5 volts.
Something that I have noticed is that when I unplug the powercable going to the sound system from the battery the battery voltage goes up to 12.45
is this normal?
can someone help.
Old Nov 12, 2006
streetglower's Avatar
yes that is normal. when the car is running the alternator is charging the battery. when the car is off nothing is charging the battery.
Old Nov 12, 2006
_SKIN_'s Avatar
Member
_SKIN_ is an unknown quantity at this point
I second that!
Old Nov 13, 2006
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
12.35 on a new battery seems low. I also wonder if something might not be correct with the cap, it may not be charging up all the way if you get that kind of a jump on the battery voltage when unhooking power for your system. What gauge power wiring are you using for the amplifiers? The higher voltage when alternator is on is normal.
Old Nov 14, 2006
thewal's Avatar
Well I disconnected the Fuse that feeds the cap, the sub and the Amps from under the hood.
So no power is going there. All the wires that I have are 4 and 8 guage.
I guess it's not the sound system that is doing that.
i also have a compustar and an led light but I am not sure if they draw that much juice.
Man this is like trying to find a needle in a haystack.
I don't know what to do anymore.
Old Nov 15, 2006
I dont see what your problem is?
everything is running fine.
Old Nov 15, 2006
thewal's Avatar
Well i was just concerned that when the car is not on and just sitting the battery is getting drained.
Old Nov 15, 2006
You'll need to do current drain testing if you want to find out for sure if you're having an issue. You need to have a somewhat decent quality meter that does DC current. Any drain over 30-40mA with vehicle off is too much.
Old Nov 20, 2006
thewal's Avatar
Well I finally figured out what the problem is. Seems that my compustar alarm system was drawing too much amperage 80 mA. Faulty module.
after i diconnected it had very little draw from the battery. Not sure how these modules go bad on you but he at least the problem has been solved.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Hutch1051
Sep 29, 2015 09:20 AM
Bruce2
Sep 27, 2015 08:45 PM
Bricoleur
Sep 9, 2015 12:23 PM
