Low beams don't work
Can anyone tell me what would cause, all of a sudden, on my 03 LX, the low beams to die. The fuses are all fine, the high beams work fine. I'm guessing either a bad relay, either under the hood or at the fuse box under the dash, or a bad headlight switch.
It happened as I was driving home, as was uninstigated. I was driving down the road with the lights on, and they just turned off. Anyone had this happen?
sounds like you just have both headlights burnt out. each headlight has its only relay and fuse. so if the highbeams work and lowbeams dont, that tells you the relay and fuse are both fine. pull both bulbs out and look at them. yes its unlikely that both fail at once, but it does happen.
it may also be the headlight switch, but I would try the easiest and cheapest first.
I had the same thing happen to my car. I put new bulbs in and still it didnt work, and the fuses were all fine. The problem is the dimmer switch, the thing that turns the lights on and off. Call ur local Honda dealer and tell them whats wrong they well replace it for free, because it was recalled. Good luck
That's what I thought, the dimmer switch. That makes sense.
Thanks, I'll call the dealer.
I would inspect Pin #6 = RED/WHT wire and look for signs of overheating.
The recall was for 01s and some 02s. If it shows signs of getting too hot I would complain to Honda. Although the parts are fairly priced IMO.
The OEM part # for the headlight switch = 35255-S5A-A02, MSRP = $28.97 (always cheaper online)
Use great caution when removing the column covers, The tabs on the lower cover are easily broken.
If you want the wiring diagram for the '03 headlights I have it. Send me an e-mail at mjats@juno.com.
From the symptoms you describe it does sound like a bad combination switch. Try this quick check:
Find a quiet area. Ignition off and key out. Turn on the low beams. You should hear the headlight relay click. No click? Try the high beams. You should now hear the relay click. If no click on low but click on high that's a good sign that the combo switch is toast. If you hear a click on low your problem lies somewhere else in the headlight circuit.
So to wrap this up (for the archives). I had no low beams headlights. The fuses were all good, and bulbs were replaced. It was the headlight switch, which I bought for about $45 from my Honda dealer and replaced it. It was a 10 minute job, and works perfectly now.
Thanks for the help!
Re: Low beams don't work
i have this problem now too. i hit the headlight though and it turns on. no rust anywhere and the bulbs have been replace with 3 different brands. i cant figure it out. i cant see a relay as the problem since they are a foot and a half away and are not close enough to be effected by the vibration.
(if it doesnt work, use a bigger hammer)
seems like a bad connection to the bulb. did you check the plug connector? it should be clean and have grease all over the holes.
mattdoc
Mar 14, 2017 12:10 PM
ORskier
May 3, 2015 12:54 PM
