Below 50 Degrees, Power Steering Whines for a few seconds
Old Oct 24, 2006
Skydivincoastie's Avatar
Skydivincoastie is an unknown quantity at this point
Every morning when its below 50 degrees, the power steering pump whines, goes away. When it whines, the wheel is slightly hard to turn. But again only when the weather outside is below 50! anyhelp?
Old Oct 24, 2006
streetglower's Avatar
I would say check the fluid level to begin with.
Old Oct 24, 2006
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
cold = less viscous = more pressure on the pump.
steering does cause a couple hundred lbs of pressure on the pump, and if you leave it pumping all the time, it could burn the old, causing it not function properly
RIPSAW
Nov 6, 2015 04:36 AM
moorebl
Aug 29, 2015 08:39 PM
silentz
Jun 17, 2015 10:21 PM
vvr210
May 31, 2015 08:02 PM
trellex
May 24, 2015 04:39 PM
