check engine light is ON!!!!!!!
Old Oct 8, 2006
well wtf i was driving on the free way 5 mins with the ac on, then i turn it all off and sit at a light for a minute, and as im accelerating up a gentle hill around 3k rpms, the cel comes on. crap so i just drive it home, it feels no different so i know its not a severe problem, then i plug in my trusty ebay code reader. it gives these codes. im not sure how to read them... but i did find the last code in the thread here its for vtec malfunction!
coded
-01-
-02-
-03-
1259 (vtec system malfunction)
now are those first 3 codes supposed to be read like 0100 for 01 like that? if so i have some serious issues. any help would be nice cause i normally have a very well maintained car that runs great.
ps. i had the oil changed and put new plugs in about a month ago and had no issues until now. nothing has been changed except dash lights color a week ago. i got gas yesterday from the usual mobil and i drove around quite a bit before now without problem.
when i turn the car to ON, the cel stays on like normal and then before going off it flashes a few times. and then it only gave the first 3 codes.
my oil level is above full, im not sure if that would cause this problem, its been like that for a month tho.
Old Oct 8, 2006
streetglower's Avatar
clear the codes and drive around and see which one comes back. not sure what the 01,02,03 mean.
Old Oct 8, 2006
i did. cleared, drove around and going up another gentle hill it came back on when rpm was between 3-4k. same codes. and when its on, the shifting becomes slower, like when you first drive before engine warms up. i cleared again and so far it hasnt come back, altho the car feels like it lost some power.
Old Oct 9, 2006
ccarbo's Avatar
ccarbo is an unknown quantity at this point
Gearbox, Not sure what scanner you have but I had similar issue. with 92,000 miles I CEL came on. Was a misfire on cylinder 1,2,3. So I replace plugs and then it did come on again like month later. This time misfire on 1 and 4. Not sure why. I switch coil packs around (1 w/ 2 and 4 w/ 3) and now see what happens. I am wondering if your 01, 02, 03 errors are the misfire errors. I did not have that Vtec error though.
Old Oct 9, 2006
i know its not misfiring, so maybe those are just nothing. i took it in to have the oil level drained to normal level, the light came on right as i drove away from the shop. so tonight im checking the solenoid filter screen. until then, i have to keep rpm under 3k.
and if thats not enough problem, my car also does not start sometimes. once a day now ive tried to start and it would just keep cranking but no engine start. finally the second try it will crank more and stumble to a start.
Old Oct 9, 2006
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
hmmm, thats weird... the starting problem sounds like that immobilizer thing but I know u usually put it to the On position for a few seconds before you crank. Possible faulty fuel filter? I dunno
Old Oct 9, 2006
could be, or maybe bad fuel pump. well i took off the vtec solenoid and cleaned the surfaces and gasket, pushed on the lil button a few times, and then put it all back. i went for a long drive used 5 gallons gas going fast and slow the light never came on. so... hopefully it was just sticking and i fixed it.
Old Oct 9, 2006
Nameless's Avatar
TURTLEonK
crap, did i say fuel filter? I meant fuel pump hahaha...
hmm lets hope so!
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
