Water Pump replacement?
Old Sep 24, 2006
CIRE5109's Avatar
CIRE5109 is an unknown quantity at this point
I want to save on labor cost. Is it difficult to replace the water pump on my 01 civic if I buy the do it yourself book at autozone? I should probably replace the thermostat as well while I am down there correct? And will I risk affecting anything else negativly while i am replacing the water pump? Thanks.
Old Sep 24, 2006
well its basically like doing the timing belt. everything comes off, and the engine needs to be timed properly. so yes, you could blow your motor doing it wrong. thermostat you could do, just because the coolant will be drained already. its nowhere near the water pump. i would also put a new crank pulley on when you do the belt. but this is all stuff you only have to do every 100000 miles
sharp66
31
Jun 12, 2022 08:45 AM
mrohitredd
18
May 14, 2015 07:35 PM
Jigee
May 9, 2015 11:18 AM
CivicVoz
Apr 16, 2015 08:07 PM
dano2005
Apr 14, 2015 01:58 AM
