blended oil
Old Sep 18, 2006
shiftlessguy's Avatar
shiftlessguy is an unknown quantity at this point
blended oil
I going to switch to a blended oil first as I've heard that with higher milage some times they leak oil.Question is what milage do you change oil.It doesn't say in the owners manuel.If I get no leaks I'll go fully synthetic.Also if you've gone to full synthetic when do you change oil
Old Sep 18, 2006
Intercooler's Avatar
Intercooler is an unknown quantity at this point
Huh? Why would you get ANY more leaks regardless? Just swap it over! You can go 5k-7.5k on Mobil 1 full synthetic. Normal Dino oil is 3k-5k.
Old Sep 18, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
Well, if you're worried about synthetics causing leaks, the only way to find out is to use an actual synthetic. Only about 10% of synthetic blends are synthetic, not 50/50 like many would like to think.
In regards to how often you should change your oil, that depends. Most importantly where/how you typically drive. If you do a lot of highway driving, you can run the oil longer than if you do a lot of stop and go city driving.
I've been running full syntheic since 7,500mi and i now have 108,500. I change my oil around every 7,500mi. Although the 2 used oil analyses i've have done indicated i could go even longer, but meh. 7,500mi is long enough for me.
Old Sep 19, 2006
Intercooler I work for Univ Minn and a professor there said that the seals in your engine are used to the older oils and with older oils seals swell up up may not with syn oil where as hench, the possible leak with higher milage engines.He does a lot of engine researh as thats part of his field
Old Sep 19, 2006
I assume we are talking about a 7th Gen here? ANY 7th Gen should have the most current seals suitable for either as stated in the manual. If they are bad or not is a different question but the oil isn't the key to that.
emich
Dec 11, 2015 12:20 PM
SidCivic
17
Aug 23, 2015 03:14 AM
fafa1234
Aug 8, 2015 06:42 PM
fecrni
Aug 8, 2015 06:15 PM
BootyDo
Jul 7, 2015 06:06 AM
