help headlight problems
Old Sep 15, 2006
02blkhonda's Avatar
02blkhonda is an unknown quantity at this point
i noticed yesterday that my low beams would not come on. so all fuses are good and bulbs are good. honda said that my car was not on the recall list. so right before they went out i smelled a wire burning smell inside the car. I have searched for this on here but no real clear cut way on how to fix it. i checked the headlight terminals with a circuit checker and the passenger side all three prongs showed current but on the driver side only one showed current and one showed a slight current and the other was dead. i think it is either the hi/lo switch or the low beam wire is burned up like another guys on here....so if anyone can walk me through on how to repair it or tell me some other things it might be i would be grateful
Old Sep 15, 2006
CraigW's Avatar
Some 02s are affected by the recall as well ----> http://www.geocities.com/pfeifferper...ghtharness.pdf
I would have them check again.
The headlights are supplied power and grounded to operate through the switch. Low beam = Pin 6 (RED/WHT wire color) is most likely what they look at. The switch is an easy replacement once you get the column covers off.
The TSBs are provided by a member here.
Old Sep 18, 2006
02blkhonda's Avatar
the honda shop ran the vin and said that my car is not on the recall....also could anybody give me a walk through on how to replace the switch thx
Old Sep 18, 2006
CraigW's Avatar
Once the covers are off there is only 2 screws holding the switch in place, it will then slide out and disconnect connector.
I would inspect the wire and the connector near pin 6 for signs of overheating. It could also be a problem.
Old Sep 18, 2006
02blkhonda's Avatar
ok where can i get a switch at cheap if that is it........also one guy said that his dim light wire burned all the way from the switch to the bulb?
Old Sep 20, 2006
02blkhonda's Avatar
anybody?
Old Sep 20, 2006
CraigW's Avatar
www.cheapesthondaparts.com Mario can fix you up. Good shipping cost as well.
Old Sep 23, 2006
recall install info is here
http://www.geocities.com/pfeifferperformance/TSBs.html
stryder12
Jun 30, 2015 08:33 PM
carid
Jun 5, 2015 11:51 PM
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
intensity
May 12, 2015 10:43 PM
shaejb15
Apr 26, 2015 07:44 PM
