Clutch Pedal Pop- i know what causes it- need answer.
set: 02 ex. manual (obvioiusly)
Clutch Pedal Pop- i know what causes it- now i need an answer.
When i push in it pops at about half way. When looking at the pedal underneath i noticed that when i hold the main bolt* (for a lack of a better word) that goes into the master cylinder upwards slightly, no noise occurs. The pedal is stiff but the bolt* is loose. i tried applying grease to it but it's not working. i can see that the bolt* can be tightened, but it seems that wouldn't work really as the main/loose part is secured by a jitter pin.
i can't find any answers using the search. if you know it, please paste the link.
thanks.
thanks.
violentpanda
Sep 7, 2015 11:49 AM
Mucklow
Aug 22, 2015 06:28 PM
martinsmartin
Aug 15, 2015 07:34 PM
JetsterDajet
Aug 15, 2015 08:07 AM
