Installing Gauges but confused on a few things help would be appreciated
420 Member
First I wanted to know if all the gauges would still work if I hooked them up like this
Then I wanted to know for the power source which grey/red wire is it behind the gauge cluster there are 3...
is it the one I did it on?
2?
or 3?
in the middle of this so any help would be appreciated o and how do I ground it? do I need to get a grounder to put behind a bolt or can i just stick the wire behind a bolt and screw the bolt in? a bolt such as the grounder for the cig lighter
2?
or 3?
thats a very thin wire to support 3 bulbs of 5 watt each. either use led bulb or pick a different power source like ignition or a new power wire. i think the red/black wire is the one for dash light.
what year is your car. i know for 01-02 the dash light is on the blue connector and its the red/black. now you can test these wires just get a tester with led light and connect one clip to ground and then put the test point into each pin to see if it lights up when dash lights are on.
mistermenphis22
Apr 3, 2016 08:06 AM
tylerginevan
Apr 27, 2015 12:29 PM
nickfn
Nov 8, 2001 09:44 AM
aZnVoYCe
Nov 7, 2001 05:54 PM
