Exhaust Manifold... UPDATE!!!!!!!!!!!!!!!!!!!
Old Jul 11, 2006
HondaSaurusLX's Avatar
HondaSaurusLX is an unknown quantity at this point
Ok.. so I bought this header... http://cgi.ebay.com/ebaymotors/01-02...QQcmdZViewItem
Now I need to know where to get those O2 SIMs for it.. I have done a search and nothing came up.. Also, will eleminating the 2 O2 sensors and the catalytic converter result in lower fuel economy? Thanks
Old Jul 11, 2006
streetglower's Avatar
sounds like an exhaust leak caused by the gasket. I would replace the gasket, it isnt very expensive. I believe less then $10 from honda.
Old Jul 11, 2006
Thanks.. I think I'll try that before I go an buy an entire new set of headers.. do you know if there is a DYI here on the 7th?
Old Jul 11, 2006
familycar's Avatar
its an easy fix. although the same thing happened to me and i did have a crack in the manifold. i only found it after i took the stock manifold off though. luckily i bought a dc header to replace it and also went ahead and did a R/T cat pipe and evo 2 exhaust with it. but the crack was about 1-1.5" long. hopefully that isnt your problem
Old Jul 11, 2006
Sinisterdexter's Avatar
I Pinch.
Sinisterdexter is a glorious beacon of lightSinisterdexter is a glorious beacon of lightSinisterdexter is a glorious beacon of lightSinisterdexter is a glorious beacon of lightSinisterdexter is a glorious beacon of lightSinisterdexter is a glorious beacon of light
It's not too tough. To remove the header at the block there's like 5 nuts. I had to use PB Blaster and Bolt-Out tools to get them off. Just remove those and the ones on the heatshield. Then get under the car and remove the two spring bolts. Once this is done you can take the two gaskets(the one on the bottom looks like a donut and the one on the top looks like two pieces of metal) and replace them. make sure you tighten everything back to spec(which I can't remember off the top of my head) and make sure to do the spring bolts equally so it doesn't tighten one side more than the other.
ooooh Also inspect the header when you have it off the car to see if it could be a crack.
Old Jul 11, 2006
Thanks ya'll... I just took the manifold off and there is friggin cracks everywhere.. WTF was Honda thinking! Anyway, looks like I'll be driving my Dodge Neon until it gets fixed, though I'd probably be better off driving my Civ without a manifold..
Old Jul 12, 2006
familycar's Avatar
since your an lx your only options are to run a kamakazie header for an lx or get e custom down pipe or swapp to an ex exhaust
Old Jul 17, 2006
Do you know of any links to these LX headers?
refer to new question.. thanks ever so.
Last edited by HondaSaurusLX; Jul 17, 2006 at 12:01 PM. Reason: Automerged Doublepost
Old Jul 17, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
Eliminating both o2 sensors is not an option. You need the first one. As far as eliminating the rear o2 sensor and the cat, i dont think that will have a negative or positive impact on your mpg.
Old Jun 8, 2007
beverly_k's Avatar
beverly_k is an unknown quantity at this point
Re: Exhaust Manifold... UPDATE!!!!!!!!!!!!!!!!!!!
Don't remove your catalytic converter. It has a huge purpose. "A catalytic converter is an emission-control product that cleans up a gasoline-powered engine's exhaust. Exhaust gases leave the engine and pass through one or more catalytic converters where unburned hydrocarbons and other byproducts of the combustion process are converted into less harmful emissions." quoted from Honda catalytic converter
that's the main reason why you should keep your cat.
Old Jun 8, 2007
02civic21's Avatar
Ricky Bobby style, IWGF
02civic21 is a jewel in the rough02civic21 is a jewel in the rough02civic21 is a jewel in the rough
mechanic kittah says danger to the manifold!!!!
i couldnt find a url to the photo
Old Jun 8, 2007
speedfoos's Avatar
Dead thread.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
jdh022764
18
Nov 3, 2015 06:44 AM
Dave Brabant
20
Oct 6, 2015 12:44 AM
TheRiddicles
Sep 21, 2015 03:34 PM
Jrosa
Sep 14, 2015 08:24 PM
