GC coilovers popping
Old Mar 3, 2002
2Hondaz's Avatar
2Hondaz is an unknown quantity at this point
YES!! I did search, but couldn't find this one. What was the solution to fixing the coilovers so that they don't pop when turning corners. I know the solution was posted one time or another, but I can't remember what it was.....BTW, my car looks phat lowered w/17's, but the front passenger side coilover is poppinh when turning. Whoever know the solution please let me know asap....THX!
Old Mar 4, 2002
FamilyMan's Avatar
FamilyMan is an unknown quantity at this point
I had a popping noise in my front strut when my springs were installed. After taking them apart I found that part #7 in the link was rubbing on the inside of the strut tower slightly. It was installed wrong and I flipped it around. Problems solved.
Front Shock Assembly
My Rice Popper
Hope this can help you.
Old Mar 4, 2002
3rdcivic's Avatar
3rdcivic is an unknown quantity at this point
According to GC, the popping has to do with the plastic bearing assembly that Honda used on the 2001 Civic's. Honda changed the design for the 2002's and are using a metal bearing assembly that can hold up to the centralized pressure on the bearing. I think that it may be possible to force the bearing to work properly by installing a rubber ring between the spring and the lower and upper machined aluminum perches that GC supplies with their coil-over kit. This theoretically should cause enough grip on the spring that the only rotatable surface would be the bearing assembly. OR...you could do like I did and order the parts for the 2002 Civic. I have not installed them yet but the assembly looks to be better. In order to do this conversion you need the following parts:
-Upper strut mount (Left and Right)
-Upper strut mount bearing (Left and Right = Same part #)
-2002 upper plate from GC
Hopefully this gains you some insight into the problem.
Terry
Old Mar 4, 2002
2Hondaz's Avatar
I could have sworn there was an easier solution. I remember a few months ago there were quite a few posts about it. I just can't remember for the life of me what the solution was!?!?!
Old Mar 4, 2002
Flash6009's Avatar
Flash6009 is an unknown quantity at this point
was it cutting the perch...on the GC coilovers you have to cut the perch
GolNat
Nov 27, 2018 03:32 PM
ricer_em2
May 11, 2016 08:09 PM
sesi
Oct 1, 2015 02:03 PM
Tedverseti
Sep 29, 2015 05:41 PM
emiixo
Exterior
Sep 22, 2015 03:53 AM
