brake squeking like a mofo
Old Jun 9, 2006
ill02civic's Avatar
ill02civic will become famous soon enoughill02civic will become famous soon enough
brake squeking like a ****
i have a hp+ and powerslot rotors on my car now....when i brake..it squeaks like how truck brakes squeks ...so annoying and embarassing ....now, i saw this anti-squeak brake thingie in autozone...where on my brakes do i apply this thing? on the rotors? no clue... would i have to take everything out ....i hope not ....greatly appreciated ...
Old Jun 9, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
maybe you didn't install it right
Old Jun 9, 2006
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
u apply that grease behind the pads where the calipers touches. and you might have installed improperly, if they are new breaks they shouldnt squel
Old Jun 9, 2006
ill02civic's Avatar
its installed right ...... i was searching through this forum ...alot of pple have problems with it escpecially w/ hawk pads ...... would the anti-squeaak spry work..if so, where would i apply it ?
Old Jun 9, 2006
krazydriver's Avatar
krazydriver is an unknown quantity at this point
okay if their installed properly and you want to try anti squeal here's how to do it.
the anti squeak stuff i had wasn't a spray more of a toothpaste consistency goop.
here's how i put it on.
Detach your lower caliper bolt and swing the caliper up. Leaving the pads on you can just spread a little of this anti squeal stuff on the metal backing on the pads. It's best to let it dry before you pull the caliper back down on it.
that's it. Considering the anti squeal is like $2-$3 it might be worth trying, if your sure everything is installed right.
Old Jun 9, 2006
ill02civic's Avatar
oh its a toothpaste tyhpe ....hMm ok....is there any spray onez ..? if not, then ima try that then .....thanks bro
Bricoleur
Sep 9, 2015 12:30 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
thaler4cuse
Sep 7, 2015 08:25 PM
Josh 1973
Sep 7, 2015 10:10 AM
rainman15
Sep 6, 2015 11:10 AM
