Engine Sounds Like A Diesel Engine???
Old Jun 4, 2006
Mardeezy's Avatar
Mardeezy is an unknown quantity at this point
Question Engine Sounds Like A Diesel Engine???
Ive changed the motor oil every 5K, and with synthetic. But for the past 3 months I noticed engine sounds wierd. At idle speed and low speeds it sounds like a small diesel engine or something. Any ideas on what it could be??????
Old Jun 4, 2006
what kind of noise? clicking sounds like valves, or loud noises? could be anything from valve adjustment to broken motor mount to clogged iac valve.
Old Jun 4, 2006
i8dabomb's Avatar
I love to suck t3h c0ck & am supr ghey
i8dabomb is just really nicei8dabomb is just really nicei8dabomb is just really nicei8dabomb is just really nice
what's wrong with sounding like you have power?
Old Jun 5, 2006
RHCP0801's Avatar
its just the usually beastly d17 but yea check your motor mounts, my brothers civic was very loud and it was just cause they were broken
Old Jun 5, 2006
Jrfish007's Avatar
How many miles on the car? Which engine or model of civic do you have?
Old Jun 5, 2006
also mine got alot quieter after using lc20 in there from lubecontrol.com. before it would actually make growling sounds.
Old Jun 5, 2006
twinbo's Avatar
twinbo is an unknown quantity at this point
Cracked Exhaust Manifold. Most likely right where the heat shield does not cover it. Apparently the Honda engineer was drunk at work when this manifold was designed.
Old Jun 5, 2006
that and the tubes get clogged to easy. that prolly what causes it when it superheats. i had mine off and there was tons of carbon around the ports.
Old Jun 5, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
probably an exhaust leak as twinbo said.
Old Jul 3, 2006
rzc's Avatar
rzc
rzc is an unknown quantity at this point
I have the same prob as well. I am going in to have it checked tomorrow by the dealer. Just curious if it's an exhaust manifold how much do they go for and does anyone have one they want to get rid off.
Old Jul 3, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
valve adjustment???
Old Jul 3, 2006
rzc's Avatar
rzc
Just In...
I just got back from the dealer to get some other work done (water pump and drive belts). Anyway, they looked into it and it seems that I do have a cracked manifold. They want too much to get it done. Hopefully it will be easy to DIY.
Old Jul 5, 2006
Mardeezy's Avatar
I was thinking it was the manifold or exhaust also. Cause I can only hear it when I am taking off. But thanks I check the valves and all that to see what it is.
Old Jul 6, 2006
Jrfish007's Avatar
It's generally cheaper to get an aftermarket header and do it your self. Often you can find the stock ones cheaper on eBay or this site too.
Old Jul 6, 2006
02BLKCIVIC's Avatar
Well **** I have a stock EX header if you want...
mrohitredd
18
May 14, 2015 07:35 PM
Lt. Dan
May 13, 2015 12:42 PM
superstanko
Apr 28, 2015 04:38 AM
TAZZ
Dec 5, 2001 09:35 PM
supercivic01
South
Nov 30, 2001 11:27 AM
