electrical problem
Old May 27, 2006
weedo's Avatar
Who is Mike Jones?
weedo has disabled reputation
electrical problem
i'm haveing a problem with my blower motor
the motor works fine and there is 12v coming to the connectors to the blower motor when its unplugged. but when i plug it in, the negative cable doesnt want to work.
the negative cable runs to a sensor in the hvac box, it is in plain sight with. this sensor is denso part 077800-0682. it has two screws holding it in and has a 4 wire connector feeding it. one comes from the motor, one goes to ground, and two going/coming from the fan speed potentiometer.
if anyone has an electrical diagram, can you tell me what the voltages accross these connectors are as well as the resistance between them.
thanks
Old May 28, 2006
CraigW's Avatar
I have some wiring info if you need it. PM with E-Mail and I will send it.
Sedan or coupe ??
CarStuff
Dec 6, 2020 12:52 PM
juror
May 26, 2015 06:35 PM
steveneddy
May 19, 2015 02:39 PM
ywgflyer
May 15, 2015 05:05 PM
Ronin
Nov 17, 2001 09:46 PM
