OIL All over spark plug... ?
Old May 9, 2006
AntiLoop's Avatar
AntiLoop will become famous soon enough
I was changing my sparks the other day, and one of the spark plugs was COVERED in engine oil, the whole chamber was soaked in oil, is this a major concern? and what could be the problem?
I cleaned it all out and put in the new spark for now, will bring it to mechanic when I can, but anyone know if this is something serious?
Old May 10, 2006
familycar's Avatar
yes its serious it means you have bad piston rings in that cylinder. do you regularly check the oil because if there is that much oil in the cyl its obciously burning it and may be low. this can be caused by a bad injector in that cyl. honda and acura are kind of notorious for that. what happens is that the cyl isnt getting enough fuel and fry's the rings eventually burning a whole in the piston. you should be able to keep an eye on the oil level and keep it full and drive for quite some time as long as the injector is fixed, if that is the problem. i have seen it alot in older year hondas
Old May 11, 2006
AntiLoop's Avatar
Thanks for the reply.
Damn that kinda ruined my day... Was planning on running this car a little while longer, but if theres going to be engine issues... that's gonna suck =|
Old May 12, 2006
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
I would bet more money on the spark plug seal in the valve cover. I just had to replace a set in my GF's vic when I took off the valve cover.
It would be #6 on this page. http://www.hondaautomotiveparts.com/...DER+HEAD+COVER
Old May 12, 2006
familycar's Avatar
that is a good point as well! it all depends on if the oil was on the electrode or not. if the oil was on the part that sparks (electrode) then i would put money on it being bad rings.
Old May 14, 2006
free_refil's Avatar
free_refil will become famous soon enoughfree_refil will become famous soon enough
Ya I had this problem too. I had a bad seal around the valve cover. Although this was on my B16a in my CRX. Just had to pull the valve cover off and replace those little round seals that go around where the spark plugs go.
Old May 14, 2006
dopes6070's Avatar
its always good to try the cheap stuff first
Old May 15, 2006
Honda01's Avatar
Honda01 will become famous soon enoughHonda01 will become famous soon enough
i had this problem on my 91 civic.
Car ran fin, but it was freaky.
Mechanic said not to worry about it - I didn't, and it never gave me a problem.
You should replace the valvecover seals and gramunts* every so often, and gramunts everytime you remove them (supposed to)
Anyways, if it bothers you, do the cheap stuff first...
Old May 15, 2006
familycar's Avatar
even if it is the piston rings you can just continue to add oil and it will be fine for a lont time if your not hard on it
Old May 17, 2006
EX4Dr's Avatar
EX4Dr is an unknown quantity at this point
There is also a small possibility of a clogged intake/air filter causing air intake vacuum to suck more air through the PCV valve. Check to see if your air filter is soaked with oil. If it is then this is a possibility. Most common cause of this is running into road debri (especially plastic bags) and having it sucked into the intake passage, causing a partial to almost full clog.
stvpagn
Jul 9, 2015 09:59 PM
1khilari
Jul 9, 2015 08:12 PM
jzhartman
Jul 9, 2015 04:56 PM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
CivicsClass101
Jul 9, 2015 11:14 AM
