idling to low?
Old May 1, 2006
teg91ls's Avatar
teg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trusted
idling to low?
When the car is in drive but stopped, im only idling at like 400, and when its in neutral its only at like 500, this seems low, How to i do the idle relearn? I held it at 3000 rpms till the fan came on and then let it sit 5 min, but it did not work.. I did this after driving the engine hot though, Does it need to be cold before i do the idle relearn? Or should i just try tightening the throttle cable?
BUMP, is the first white line on the rpm's 0 or is it 500, i searched and got different responses.
Vanman
Jun 9, 2015 08:17 PM
The Big Dutch
Jun 9, 2015 07:49 PM
jakeconnor
May 5, 2015 07:30 AM
Firefly
80
Sep 23, 2005 11:40 AM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
