bad strut
Old Feb 27, 2002
vandal's Avatar
vandal is an unknown quantity at this point
bad strut
Dont know if I'm the only one, but i got my car inspected last saturday, and i have a bad strut, its leaking. So i took it over to the dealership and they were great put another right on. But still i only have 8000 miles on the car, shouldnt need a new strut.
Old Feb 27, 2002
avenger's Avatar
avenger is an unknown quantity at this point
oh well, at least the dealer didn't hassle you [IMG]i/expressions/face-icon-small-smile.gif[/IMG] [IMG]i/expressions/face-icon-small-smile.gif[/IMG] [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 27, 2002
Ronin's Avatar
Ronin is an unknown quantity at this point
Was the strut making any weird sounds when you went over bumps? Cuz I think I may have a bad strut too. It makes a knocking sound whenever I go over a speed bump (left front side).
Old Feb 27, 2002
vandal's Avatar
yeah it did make a funny noise over bumps, almost like a knock, and my problem was on my front drivers side. the best way to check is to jack the car and remove the tire and look around to see if here is any grease or oil that seems out of place behind the tire. or if you have access to a lift check it out there.
Old Mar 7, 2002
jagradar's Avatar
jagradar is an unknown quantity at this point
Brought mine into the dealer the other day and complained of rough ride. Dealer replace front springs and struts. No hassle. Ride has 30,000 but still struts should not blow so fast.
Old Mar 9, 2002
Cristo's Avatar
Cristo is an unknown quantity at this point
My honda had the SAME problem! it happened at 8,000 miles too ........Is HONDA GOING CHEAP ON US??
Old Mar 13, 2002
jagradar's Avatar
Honda replaced struts and springs. I ordered Koni yellows and neuspeed sports. I asked the dealer if he would put my parts in and keep his stock crap. ABSOLUTELY NO WAY!
Old Jul 8, 2002
snowman2002's Avatar
snowman2002 is an unknown quantity at this point
I'm having the same problem with the knocking noise from the driver's side. It only happens at low speeds. I took it to the dealer. They said it would cost $70 to look at it because my Goldline springs voided the warranty. I think I'm going to put new struts on the front. I have looked at the struts for fluid leak. So far I haven't noticed anything. Of course, I'm not sure where to look.
Old Jul 8, 2002
Ronin's Avatar
Next time you go for an oil change, ask them to check your struts for leaks. They can tell right away... much easier to see when your car is jacked up in the air.
Old Jul 11, 2002
lemoncivic's Avatar
lemoncivic is an unknown quantity at this point
I saw a ton of goldish syrup lookign stuff sitting right on my springs on the left front strut. It was easy to see just by looking in the area above my tire under the fender. Yours may just not be that bad yet. My car isn't lowered though, it's stock so it's very easy to see.
Old Jul 12, 2002
Well, my front driver's side shock was blown. I replaced the front one's last night. I compressed the one that I suspected was blown. It went down, and never came back up. It's my fault. I drove the car really hard after putting my Goldlines on. I was so happy in the ride quality, I did consider the hell I was puttig them through would blow my strut.
Lesson learned! [IMG]i/expressions/laugh2.gif[/IMG]
Old Jul 12, 2002
beamer's Avatar
beamer is an unknown quantity at this point
That's funny. At first I thought the noise was coming from under my dash, but then I stuck my head out the window gonig down a rough driveway. it has to be the strut. mine only has 6500 on it.
mistermenphis22
Jul 13, 2015 04:43 PM
cgavin1
Jul 7, 2015 07:10 AM
BootyDo
Jul 7, 2015 06:06 AM
robbie374
Jul 7, 2015 02:56 AM
GH04si
Apr 15, 2015 08:13 PM
