NO HEAT ON MY FEET
Old Feb 26, 2002
TAZZ's Avatar
TAZZ is an unknown quantity at this point
NO HEAT ON MY FEET
Hey, its the old man!!! I took my EX to the dealer so they can look into why I have no heat coming out the floor vents. I have an EX 2-door with AEM CAI, DC sports ceramic header and Thermal rear section, as if that matters!
I got no heat coming out the floor and when I zip my 42 mile ride to work in the weeee hours with temps near 0 my feet get a little chilly.
The dealer told me that I had to close the side vents, punch the re-circulate button and blast it away. My first thought was that this was BS and I was being dismissed. But I'll have to see!
Is the a design flaw???? Does anyone else have this problem? You young bucks probably don't get cold feet like me.
LET ME KNOW!
Old Feb 26, 2002
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
Can't say I have experience that problem.
However, I figured Young Boys would get cold feet lot more than the older fellas. Figured the older fellas would be used to it by now! LoL [IMG]i/expressions/laugh2.gif[/IMG]
[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Feb 26, 2002
Spider883's Avatar
9K Redline Owns U
hey i havent had a problem here with the vents. and the dealer is giving u the run around. so if what they said doesnt work take it back and b itch at them
Old Feb 26, 2002
Ronin's Avatar
Ronin is an unknown quantity at this point
No, it's not just you. My feet vents are *** weak too. Stuck my hand down there once, and barely felt anything even with the feet setting on full. Gonna try closing the side vents next time.
Old Feb 26, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
ive never set it to feet, ill have to try it and see if it works
Old Feb 26, 2002
Flash6009's Avatar
Flash6009 is an unknown quantity at this point
i have that problem every time i use the heat...i put it on floor and it blows on my face...damn the civic are put togethor so badly that it makes me change my feelings on hondas all togethor
Old Feb 27, 2002
TAZZ's Avatar
thanks for feedback. This dealership ain't bad. At first I thought it was BS but I think the 7thGen needs a tweak or two. I still like the car.
Old Feb 27, 2002
Vinas's Avatar
Vinas is an unknown quantity at this point
Ive experiences the same problem, almost no heat coming out from the lower ducts
Old Feb 27, 2002
VTECpnay01's Avatar
VTECpnay01 is an unknown quantity at this point
[IMG]i/expressions/face-icon-small-frown.gif[/IMG] that has happened to me... but what i've found was that if you just turn the dial to floor only and put it on heat... it'll blast your feet with some heat... well thats what i had to do!!
[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 28, 2002
AceKicker's Avatar
AceKicker is an unknown quantity at this point
hey old man. Ya i have the same problem too. i will ev en blast the bottem vents and its like where the heck is the heat. I think it is a flaw because when i went to figure it out the vent aims up higher then where ur feet sit so the vent does work they just need to fix the vent and aim them lower.
Old Feb 28, 2002
Bdubb's Avatar
Bdubb is an unknown quantity at this point
Yes, thank you for putting this post up I have the same problem I keep checking the radiator fluid to see if that is the problem and even took it to the dealer I get no heat on the floor and my windows fog up which is really hard issue to drive with -b
Old Feb 28, 2002
Intruder's Avatar
Intruder is an unknown quantity at this point
Yeah my feet vents blow too (little that is), though I hardly notice it, but they are really weak.
Old Feb 28, 2002
astr033's Avatar
astr033 is an unknown quantity at this point
Whenever I have a passenger he or she says that they can feel the heat on their feet. For some reason I can't feel it on the drivers side. Strange....
Old Feb 28, 2002
crazybluehonda's Avatar
crazybluehonda is an unknown quantity at this point
hello yes i have the same problem. i live in saskatoon which right now its -38 out side and my feet are cold
Old Mar 1, 2002
tcneo's Avatar
tcneo is an unknown quantity at this point
it happened to me too, but whenever i press on the clutch then i feel the warm air blowing, i think it's just the location of the vents, and warm air usually goes up... if the fan is not strong enough... it'll rises before it hit your legs
just an idea
Old Mar 1, 2002
TheGuy's Avatar
TheGuy is an unknown quantity at this point
I've noticed the same thing; I guess it's just the way the car is designed.
On the good side, the top vents are in perfect position to be mini hand warmers.
Old May 15, 2002
bw's Avatar
bw
bw is an unknown quantity at this point
It's official, no heat on the feat was part of the design of civic. I have the same problem. My dealer told me it was operating normally. I then took in a high speed thermometer which showed the dash and defroster ant 130degrees and the floor vent in the fifties.
They brought out another 2001 civic and it did the same thing. They suggested calling Honda USA. After many phone calls they closed my case saying the car had no defects and was working as designed.
So maybe floor heat was an option I didn't know about...[IMG]i/expressions/face-icon-small-mad.gif[/IMG]
h4ldol
Apr 24, 2017 08:16 PM
Munzy
21
Oct 7, 2015 07:48 AM
hondalx2002
18
Sep 15, 2015 10:54 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
